View Full Version : L92 fuel injector plugs
71maroesteban
12-12-2013, 01:11 PM
How do I get these connectors off? It's probably stupid easy but I've been trying to get them off for a while and I don't want to break them is there a trick to remove them thank!
Samckitt
12-12-2013, 01:53 PM
IF they are the same as the LS2 on the Trailblazer SS injectors, there is a gray slider that you move & then you can use it to squeeze against the connector body & it moves a finger that allows it to slide off the injector body. Hard to explain without one in front of me.
71maroesteban
12-12-2013, 02:19 PM
Thank you so much your a life saver I got them!
