View Full Version : GMPP 454 Kit?
dhanks
04-21-2014, 09:09 AM
Hi all,
Looks like Jegs and GM have a new kit available for the LSX454.
http://www.jegs.com/i/Chevrolet-Performance/809/19260833K2/10002/-1?parentProductId=2675108
Can someone help me understand what else is needed to make this engine turn-key?
From what I can tell, it's only missing the front assembly.
Schwartz Performance
04-21-2014, 09:32 AM
Yeah the front drive and flywheel/flexplate and all that jazz.
-Dale
dhanks
04-21-2014, 09:34 AM
Thanks, Dale. Have you used these kits before? Also, can you be more specific on "all that jazz" :-)
I'm not an engine builder, but I can put stuff together. I'm just wondering if this kit would allow me to build a turn-key 454. I don't want to deal with tuning and other stuff.
04-21-2014, 10:23 AM
I was just referring to the transmission & such.
You'll need to fine-tune it after its running, but this kit will give you a baseline to start from and at least get it running.
What are you putting this into? Most people go with other oil pan kits, since the GMPP has a pretty deep sump (ground clearance)
-Dale
andrewb70
04-21-2014, 12:59 PM
I don't see an accessory drive with that kit.
The oil pan is a throw away, since it hangs too low. The rest looks good.
dhanks
04-21-2014, 01:01 PM
Just realized this is an 8-bolt crank - so that's a no-go since I'm using a T-56 6sp.
What a hassle it is to get all of these things in order!
andrewb70
04-21-2014, 01:05 PM
Why no go? Just get any clutch designed for a LSA engine and use that with the T56. A stock LSA has a dual disk clutch.
dhanks
04-21-2014, 01:07 PM
I want to use a McLeod RXT clutch with it.
andrewb70
04-21-2014, 01:09 PM
Do they offer it with a flywheel for the LSA engine? If so, you're good to go...If not, there are a ton of excellent clutch options, and personally I would not over look the stock LSA clutch. It seems a little odd to base an engine choice based on the kind of clutch you want to run.
04-21-2014, 01:47 PM
They do offer a clutch & flywheel kit for an 8 bolt... part number 6405807M from McLeod, steel flywheel .
-Dale
sjaroslo
04-21-2014, 01:57 PM
American Powertrain also offers an 8-bolt Science Friction flywheel that lets you adapt a regular 11" clutch to it--although it does sound as though you have your clutch selected. But as Dale pointed out, you're in luck, if you have your heart set on a McLeod, they make a setup for this flywheel. Sounds like you will be sitting pretty!
sjaroslo
04-29-2014, 11:02 AM
What have you decided to do?
dhanks
04-29-2014, 07:51 PM
Hi all,
Just an update here. I decided to go with GMPP LSX454. It's an 8-bolt crank, and luckily McLeod had an RXT clutch kit to make it work with my T-56. McLeod was nice enough to swap out my existing clutch kit and get me what I needed.
Twinstang
04-30-2014, 12:53 PM
Any pics ?
dhanks
04-30-2014, 08:36 PM
I'll start a build thread shortly. I have tons of pictures.
