View Full Version : Bellhousing... did i order the right one
XLexusTech
08-15-2013, 04:17 PM
Sanity check.. is this the right Bell for an LS3 t56.. saw something about limited to an 11" clutch? Is that OK?
http://www.summitracing.com/parts/qti-rm-8020/applications
and Flywheel or clutch recomedations? I went with the LS3 480.. was lookinag at a RAM.. kit.
thanks for any advice.
badazz81z28
08-17-2013, 10:52 AM
I have a Quick-Time set-up for my LS1/TKO and said the same thing...11" clutch. I got a hold of the folks at Monster Clutch and they sold me a 12" clutch. It fit fine in the Quick-Time. I would call them up, Killer guys and great clutch! I'm pushing about 460 horsepower to the tires.
Schwartz Performance
08-17-2013, 10:25 PM
We use stock LS7 clutches up to 700hp, cheaper route to go at only $500ish including flywheel :)
XLexusTech
08-18-2013, 03:18 AM
Wow.. good to know... do you happen to have a part number
Found this..24255748 – LS7 Clutch (Includes Clutch Disc & Pressure Plate) will this bolt to a 6 bolt crank (LS3)
08-18-2013, 08:21 AM
You'll need that and 12571611 which is the flywheel. Plus hardware of course . There are a few LS shops online like Texas Speed and Tick performance that sell them as a complete kit for $500-600.
badazz81z28
08-18-2013, 08:37 AM
You will get mixed reviews on the LS7 clutch. I know people do use them have had good success but it seems most LS guys use a Monster.
Depending on the purpose of the car, a LS7 clutch will do.
My Monster is rated at 550/550 and came with a SFI billet flywheel. I'm pretty sure the LS7 is iron.
LS7 Clutch Pros N' Cons - LS1TECH (http://ls1tech.com/forums/manual-transmission/1556783-ls7-clutch-pros-n-cons.html)
jamier2
08-18-2013, 06:21 PM
That's the same bellhousing I am using on my LSX/T56 Magnum. Fits perfect so far.
