View Full Version : What exactly is needed to make a ls actually turn and run in a classic muscle car
71maroesteban
01-16-2014, 06:53 PM
From what I've read and please excuse me if this is a over talked about subject but what exactly do I need to make this thing run in my car I never planned on doing an ls swap well not for a while in till I was done with school but the engine just fell on my lap the engine is a vortec l92 so here is what I have and would like to know what I need to get it going
Fbody oil pan with improved racing baffle
Engine harness off of the car(wiring is my weak point) so gonna need a lot of insight on this
Dirty dingo slider adapter plates
Speedtec t56 cross member
Now is there anyone I can send my harness too to be reworked to be standalone and work with the t56 also I plan on keeping the vvt and running an ls3 intake thanks guys again sorry if this is a over talked about subject
71maroesteban
01-16-2014, 06:56 PM
Oh I forgot the fuel situation I plan on using tank incs setup
csouth
01-16-2014, 08:01 PM
Lots of sources for harness rewire work, just depends on your budget. I used lsx-harness.com, after hearing from satisfied customers on LS1tech. He is fair priced and is available even on weekends if you need support. It will come with a small fuse panel, relays and connections labeled. He'll pull out all the trans wiring as he did for my LS2 from a TBSS.
The Dirty Dingo sliders, F Body pan and Improved Racing baffle are all good pieces. With the Tanks inc setup, you will still want to get a LS1 Corvette FPR/Fuel filter. You'll also want to find some after market fuel rails or stock LS3 rails as I don't think the truck rails will not work with a car intake.
72BBSwinger
01-17-2014, 02:06 AM
I plan to use the Gen III Hemi version of these guys offering, http://www.efisource.com/shop/ms3-lsx-plug-and-play/
garys 68
01-17-2014, 06:03 AM
You didn't say what kind of car it's going in. You're best off finding a similar swap here or over at LS1tech, use that as a guide.
71maroesteban
01-17-2014, 03:24 PM
You didn't say what kind of car it's going in. You're best off finding a similar swap here or over at LS1tech, use that as a guide. oh yea sorry a 1971 Camaro and I've read a lot of them I get that you have to use adapter plates change the fuel pump to one for fuel injection it's just the wiring that I do not understand does the engine need it's own fuse box? Or do I just hook the computer to the battery and to ignition? I know how to get it into the car just have no idea about the sensors and wiring
csouth
01-17-2014, 09:04 PM
When you send the harness out to get stripped, it will come with its own fuses and relays. Most are a 3 wire connection, key on power, constant power and ground. The sensors will be labeled on the harness when it comes back, just plug into the appropriate sensor. Do yourself a favor and invest in at least one LS Swap book.
andrewb70
01-18-2014, 08:30 AM
If you have a 2nd gen f-body, I would look at the new Holley system, that includes mounts and crossmember. It is by far the best engineered solution that I have seen so far.
zamora7
02-05-2014, 10:44 PM
Give the guys at car shop Inc a call. They got great parts to make your swap. I have their one inch set back plates and with an fbody pan it fit like it belongs there. I had ordered some gauges and they called me to tell me it had shipped and asked about my build. Mine is a ls1 and t56 but I still need a cross member, they are going to hook me up with a Holley cross member for second gen to see if it fits with their plates.
