View Full Version : Starter opinions?
AWDPete
02-21-2014, 03:59 AM
So the new LS needs a starter. It's a 11.0:1 compression ratio 427. I see Powermaster and MSD have some good options, but not sure what i "need". Do i "need" a 4.4 to 1 reduction 3hp starter motor? Seems to me these brutes will spin the motor over slower... just looking for a reliable starter that will do it's job. The Powermaster does make claims of being "hot start-proof", anyone have any experience with them?
Schwartz Performance
02-21-2014, 11:57 AM
Stock ones will work, LS7's are high compression. Can't go wrong with a lifetime warranty from one of the auto parts stores either ;)
-Dale
snappytravis
02-21-2014, 05:47 PM
Make sure whatever one you get that your wiring will work, I had a powermaster and I believe it was a magnetic drive, I spoke with powermaster and they said you should jump from solenoid to start wire, If you plan to mount a solenoid in trunk and battery, I would call powermaster if you go that route.
71RS/SS396
02-22-2014, 06:29 AM
Nothing wrong with the stock one, mine has served me well with the built LS7. It has lived through extensive track time and even a clutch going poof, I literally had to extract clutch fragments from inside the nose cone.
