View Full Version : LS Swap and ECU mounting location?
Tom5410
11-30-2013, 09:51 PM
Guys, I am finally pulling the trigger on a LS swap into my 67 Camaro. I am going to also be doing a vintage air set up as well. I want my engine bay to be super clean and do not want to mount the ECU for the EFI LS in the engine bay. Where are you all hiding this stuff for a clean install. Was going to put under glove box but do not think that will fit with the AC unit being there?
Any pictures or suggestions of your installs would be very helpful!
Thanks!!
Schwartz Performance
11-30-2013, 11:32 PM
You can mount it under the dash if there is room, we've also mounted them under the console, behind the kick panel, possibilities are there, you just have to be creative :)
-Dale
alocker
12-01-2013, 06:21 AM
I have mounted ECM's both inside and outside of the car. I don't think its worth the hassle to mount inside. My last build I used a long harness and ran it from the back of the engine, over the heater box, through the fender and mounted it next to the battery on the passenger side. When you install the battery cannot see it.
mikeextrafast
12-01-2013, 05:09 PM
What harness did you use to do this?
alocker
12-01-2013, 06:21 PM
I used a Current Performance Wiring with a 6' extension. The main break comes off behind the passenger side head. I sold the car but there are pics in the link below.
https://thelockers.shutterfly.com/61
