View Full Version : Engine Miscellaneous
Pages :
1
2
3
4
5
6
7
8
9
10]
11
12
13
14
- 350 Crate Motor Teardown? (15 replies)
- new top end!!! (2 replies)
- PCV valve ideas?? (7 replies)
- Is a 235 cc head too big for a small block 434? (11 replies)
- Oil cooling. (15 replies)
- older bbc to efi conversion (7 replies)
- Who makes GM Pistons (5 replies)
- 1.5 or 1.6 roller rockers for my set up??? (3 replies)
- throttle body spacer (what does it do) (3 replies)
- Solid Roller (16 replies)
- Stroker Question, 383 or 408? (0 replies)
- Engine Stand (1 replies)
- Is my engine internally or externally balanced? (14 replies)
- Dyno question (5 replies)
- Oil pan for peace of mind - 68 Firebird (10 replies)
- Morse to pinch clip throttle cable swap? (6 replies)
- Engine hoist lift plate?? concern (5 replies)
- What are these holes? (4 replies)
- Which Lokar thr. cable for .71 Camaro?? (1 replies)
- hehe super micro size SBC (8 replies)
- Fuel system returns (0 replies)
- Need Answers Fast! (8 replies)
- Ford engine decision.........large or small? (20 replies)
- GM Crate motor cam selection (4 replies)
- How much power are we talking about here? (19 replies)
- 385 FB steaming oil? (1 replies)
- 5.3 L vortec motors (7 replies)
- Which intake? (4 replies)
- Help, Help (3 replies)
- -Throttle by Wire- (5 replies)
- SBC Locking Oil Dipstick, anyone know? (4 replies)
- Carbon fiber valve covers finally arrived today... (22 replies)
- 427 clutch pivot ball (1 replies)
- Vented gas cap (3 replies)
- Confused about engine balancing... (5 replies)
- closed or open chamber heads (4 replies)
- Roller rockers? (1 replies)
- solid roller lifters, horizontal or vertical lifter bars? (1 replies)
- Belt noise (2 replies)
- Shredded the distributor gear (12 replies)
- Valve cover bolt not starting (2 replies)
- 396 Crank Question (6 replies)
- Chevy 2 piece valve covers ..anyone??? (1 replies)
- Engine Install Question (2 replies)
- World 540 cam (11 replies)
- Cc305 7 305-8 (1 replies)
- 572 intake height? (0 replies)
- 1.84 valves in a 350 (7 replies)
- LT1, LT4, Forgotten??? (28 replies)
- Engine Help (31 replies)
- firebird 400 swap (10 replies)
- 400 SBC + 400 turbo trans a good combination?? (3 replies)
- Hydraulic roller lifter help (0 replies)
- LT4 hot cam valve springs (2 replies)
- Does anyone have a Nelson TT set-up... (11 replies)
- Where to mount fuel regulator. (6 replies)
- How to tell if a 1970 Chevy is numbers matching? (3 replies)
- American Muscle Car Engine tests (7 replies)
- How to tell if your motor turns over. (2 replies)
- Need help (1 replies)
- HELP cant keep car running after changing gas tank/fuel sender (13 replies)
- looking for an engine (26 replies)
- budget "F-Bomb" engine (14 replies)
- Hey SB Chevy guys (8 replies)
- Well got a heck of a deal on a different engine,, (2 replies)
- Dramatic drop in Oil pressure, help!!!! (2 replies)
- Afr 210 Heads (1 replies)
- Noise at low RPM, goes away at off-idle (8 replies)
- ZZ4 Spark Plugs (0 replies)
- For resale 2 bolt or 4 bolt? (6 replies)
- Destroked high-revver... ? (17 replies)
- Problems with my new engine, need direction please.. (6 replies)
- Sta-bil? (4 replies)
- BBC, getting the good and bad ports close? (0 replies)
- turbo v8 or lt1 (3 replies)
- Aftermarket block or used? (7 replies)
- Help me pick a mini starter (5 replies)
- 327 engine upgrades (8 replies)
- Vortecs and Beehive springs (4 replies)
- Cam bearing oil hole location. (2 replies)
- Tall valve covers in my 67 (4 replies)
- Cast iron vs. cast steel crank (1 replies)
- LSX carbon v/covers (8 replies)
- Are MTI 2E ls6 head better than Patroit lsg cnc heads? (0 replies)
- Is a 300hp 20mpg Gen-I sbc possible? (9 replies)
- ?s about building an LT1 383 (2 replies)
- Whats a good road race motor? (24 replies)
- PCV valve needed? (3 replies)
- Heim joints for alt adjuster (1 replies)
- 300 Ford six info needed. (0 replies)
- 2001 Chevy Camaro Trouble (10 replies)
- engine troubles! (3 replies)
- For the people who dont take the Pontiac catch up race serious! (41 replies)
- What water neck to use? (12 replies)
- Valve Covers: 400 Pontiac (18 replies)
- Engine Oil Leaking from Breather? (7 replies)
- My Camaro eats Distributors? (7 replies)
- Victor Jr water passages.....plug or connect (0 replies)
- Low Compression Smog Big Block Turbo Question (2 replies)
- Help! Boiling Fuel (5 replies)
- Need engine starter help ASAP (7 replies)
- engine casting #'s (4 replies)
- 3" Flowmaster Exhaust (4 replies)
- Cold solid lifter lash (5 replies)
- 1000hp 351 winsor? (13 replies)
- SBC Steel Crank Identification (3 replies)
- Autozone Big Block? (7 replies)
- quickchange carburetor (1 replies)
- carburated lt1 (5 replies)
- SBC pro's or afficionadoes...need a price check. (8 replies)
- engine internal color (1 replies)
- Intake Tightening Sequence (3 replies)
- Any try these on stainless tubing ?? (2 replies)
- 180° crank for Pontiac engines? (20 replies)
- sbc oil pressure drop ? (3 replies)
- 96 LT1 engine code VO808YSU (0 replies)
- tall bbc valve covers (2 replies)
- octane argument (16 replies)
- early sign of detonation (0 replies)
- LT1 valves (3 replies)
- dart heads (8 replies)
- What does it take to build a BBC 496? (5 replies)
- Best electric water pump for a Big block Chevy. (9 replies)
- sbc 420 combo (6 replies)
- My engine situation (BBC) (1 replies)
- lt1 brackets and assocc. (2 replies)
- Teflon lined braided hose - Anyone use this? (11 replies)
- How much $ for a 396? (3 replies)
- sportmans ll heads???? (2 replies)
- New BBC Crate Motor w/o clutch Pivot location (5 replies)
- engine forums?? (0 replies)
- BBC--Piston wall scoured--am I screwed? (6 replies)
- Piston wall scoured--am I screwed? (0 replies)
- Pro Comp aluminum BBC heads any good? (6 replies)
- Head specifications 3927185 1970 (6 replies)
- New BBC for the chevelle what to do? (11 replies)
- Big Inch Small Blocks... (7 replies)
- Oil leak + backfire through carb (2 replies)
- sbc issues?? (11 replies)
- Problems with 69 camaro motor (5 replies)
- sbc 400 ??? @ DCR & CR (2 replies)
- Noise - Hydraulic vs Mechanical Roller (2 replies)
- Brodix -2's enough for a 572ci BBC? (3 replies)
- Difference between Merlin III and big M big blocks. (3 replies)
- Dyno results in (5 replies)
- Timing Set Questions (5 replies)
- Pontiac engine code help needed......... (5 replies)
- How does this cam wear look? (12 replies)
- Cam size and maintinance (1 replies)
- Firing order! (3 replies)
- Cleveland-pick-a-part (0 replies)
- Crappy day at the dyno (16 replies)
- What is the longest stroke that will fit a stock BBC block? (3 replies)
- D/D Help. (6 replies)
- 350 w/bigger crank? (21 replies)
- Chevy BB 302??? (17 replies)
- Filtermag (2 replies)
- What CR for a 1000hp BBC with Pro charger (14 replies)
- lowering compression (5 replies)
- Difference between Pontiac 350 and Chey 350? (17 replies)
- Hiding and Tucking wires? (5 replies)
- Piston -> Valve clearance checking (11 replies)
- Backing off valves w/shaft rockers (2 replies)
- FORD 390 info ? (7 replies)
- Afr 210 Heads (4 replies)
- Sanity Check--Solid Motor Mounts? (11 replies)
- 550-600 hp sbc (6 replies)
- Port Matching Vortecs?? (6 replies)
- gm's serp kit? (12 replies)
- Road race pan baffling (3 replies)
- Cam lifters / Assembly lube / storage (0 replies)
- Noisy Valvetrain (10 replies)
- How to get 650 horse from my 396? (4 replies)
- fuel fittings AN NPT and ? (4 replies)
- Block Fill (6 replies)
- Ford Pulleys (1 replies)
- Dynometer in Long Island, NY (1 replies)
- Can Someone DD my motor? (2 replies)
- 01 durango p0700 code!! (3 replies)
- BBC hydraulic roller and beehive springs (0 replies)
- 400 long block motor?.. or 350? (17 replies)
- Why did they do this???? (9 replies)
- Looking for help on my mopar !?!?! (5 replies)
- one piece and two piece blocks?? (3 replies)
- porting & polishing Alum heads (5 replies)
- oil press. holes in block? (5 replies)
- Canton Pan (3 replies)
- hyd. roller cam rpm's (8 replies)
- Ford engine weights (4 replies)
- Weird starter issue (3 replies)
- 400 Balance Plate/offset (3 replies)
- Went dead? (13 replies)
- Mini Starter (14 replies)
- Desktop dyno this 400 Sbc? (3 replies)
- Do these timing #s look scorrect? (4 replies)
- Ford 4.6L vs. 5.0L Modular Engine (9 replies)
- timing or fuel? (1 replies)
- compression guess?? (2 replies)
- crate motor, crank turning (11 replies)
- 454 ideas? (3 replies)
- Belt drive worth it for solid roller SBF? (0 replies)
- 632 BBC in 68 Camaro (0 replies)
- Need help finding correct throttle cab. bracket!! (0 replies)
- cant set installed height (1 replies)
- Olds' mill (6 replies)
- 355 with bowtie heads??? not enough power! (15 replies)
- 396 Question ? (4 replies)
- 502 hood clearance??? (3 replies)
- 500 Caddy questions (7 replies)
- dse pulley ? (7 replies)
- You usin' a Melling oil pump? Better read this!!! (4 replies)
- Motown / Bill Mitchell 427 SBC (0 replies)
- engine quest heads (3 replies)
- Anyone...300z help needed (7 replies)
- Engine advise.. and contest of sorts (2 replies)
- Energy Suspension poly motor mount torque specs (1 replies)
- 502 bare blocks (1 replies)
- LT1 Engine (10 replies)
- Classic Chambered exhaust? (3 replies)
- Lift exceeding flow. please advise (2 replies)
- GMPP 18° heads (5 replies)
- Have been debating building a 383 LT1, what crank? (19 replies)
- What is what I have worth? (0 replies)
- Eagle crank need balancing? (8 replies)
- Main girdle Question. Ford Guys can help too. (2 replies)
- need to find headers.. and does this sound like 500hp? (8 replies)
- Holley carb adj. question (2 replies)
- Any ideas on cheap thermo barriers for intake bottoms? (4 replies)
- Main bearings - Please take a look (5 replies)
- Desktop Dyno Request (0 replies)
- Who makes this Air Cleaner? (20 replies)
- rear seal options (2 replies)
- Any Engine Builders? (5 replies)
- dyno numbers, help explain (0 replies)
- BBC, Edel-RPM Intake, Cowl Hood, What Air Cleaner? (0 replies)
- Horsepower to Weight Ratios (3 replies)
- Lifters off-center of cam lobe - normal? (7 replies)
- Harmonic balancer runout - what's acceptable? (5 replies)
- LS6 454 teardown - need help identifying cam (3 replies)
- Sending Unit Has Two Lines? (0 replies)
- pontiac to chevy (1 replies)
- oldstyle valves in vortec (1 replies)
- changed water pump, now car is missing? (5 replies)
- Holley Avenger 770 running extremely rich...Help! (0 replies)
- who makes this air cleaner (3 replies)
- Help me choose a 427 small block (14 replies)
- whats your guys take (12 replies)
- need help quick (9 replies)
- Engine Gurus (1 replies)
- Need help picking a engine. (8 replies)
