dropit69
11-24-2006, 03:03 PM
ok gonna toss engine i have lying around in my 69 bird its a chevy 383..what do i need motor mount wise to adapt this..ive never been down this road..
I would think the frame is drilled for either engine so all you should need is the correct frame mounts and engine mounts. Having both a 69 Camaro and a 69 Firebird, I would think you could use the Camaro as a guide. You will need the P/S set up and to move the battery and alt to the other side. TCI sells adapters for the BOP trans bolt pattern to the Chevrolet.
