View Full Version : 427 clutch pivot ball
67cam
05-21-2007, 08:01 PM
Where does it go? I took the old one from my 350 and can't find a location for it. On my 350 it was above the oil filter. on my 427 there is a small oil pressure gauge hole above the oil filter. Could I tap that larger and use it as the clutch pivot ball location. Also any suggestion on how to keep my power steering, front disc brakes booster and windshield washer motor? They all have clearance issues.
HILROD
05-21-2007, 09:07 PM
There should be one or two tapped holes in the block for the pivot ball. The lingage and rods are different for a big block. If it is a newer block there are no holes, but you can get an adapter to use the pivot ball. Some car had notched valve covers for big block booster clearance. Tall valve covers won't work without mods. Also some wiper motors can have clearance issues. Most stock motors should fit, again tall valve covers won't work.
