View Full Version : What are these holes?
McGuire
06-02-2007, 02:44 PM
Hey guys,
This pic is of a new ZZ SBC crate motor. What are the two holes for at the rear top of the block near the bellhousing flange. There is a set on both the drivers side and passenger side, one hole is threaded and all the way through and the other is a little bigger, no threads and does not go all the way through. Thanks for any help.
Mcguire
https://static1.pt-content.com/images/pt/2007/06/100_0538-1.jpg
HILROD
06-02-2007, 06:40 PM
Assembly holes, probably. The small holes are used on some older Vettes to hold wire looms. They would be un-needed for you.
McGuire
06-03-2007, 02:36 PM
Thanks Hilrod, appreciate the help.
PARKERRS
06-04-2007, 04:04 AM
They are for the plug wire loom clips. Chevy sells a set of plug wire looms for the ZZ engines and one goes on each side of the block here. They have a small screw in the threaded hole and a bent tab to keep them from twisting goes in the other hole.
MonzaRacer
06-14-2007, 09:04 PM
They Arealso Used For Milling Registers Too.
