View Full Version : Sanity Check--Solid Motor Mounts?
Bandit
01-27-2007, 02:57 AM
Solid motor mounts like this for my primarily street-driven car--good idea or no?
https://static1.pt-content.com/images/pt/2007/01/mor62630-1.jpg
Would there be a handling/throttle response difference enough to make them worth it, or would they just rattle my teeth out on the street? Anybody run them in your PT car?
Yelcamino
01-27-2007, 03:06 AM
My Vette has a solid mount on the driver side and a rubber mount on the passenger side. It's not bad at all. I don't know how it would be with two solid mounts.
jasonsnova
01-27-2007, 05:41 AM
i have a soild on drivers side and regular on the pass side, its fine except when your idleing.....makes the whole car shake! going down the rd you would never know.
DarkoNova
01-27-2007, 10:07 AM
Yup, I got a solid and rubber, too. I haven't noticed much of a vibration increase anywhere (specifically at idle).
I don't think there'd be an increase in throttle response, but it's cool to rev it and have the whole car move. :smoke:
Matt
Twin_Turbo
01-27-2007, 10:37 AM
both solids and a urethane trans mount.
LowBuckX
01-27-2007, 02:58 PM
Both solids and a rubber trans mount here I dont mind it at all but I will be putting a ruffer cammed motor in soon so my mind may change.
If your running a small block make sure you dont use a newer melling oil pump or it will break. You need a Mselect pump.
chicane67
01-27-2007, 03:34 PM
I ran solid engine and rubber (or poly) transmisson mounts for years... and loved it. Solid engine mounts to tend to stiffen up the front cradle, which is a good thing for turning corners. I would not... run solid engine and trans mounts on a street chassis.
However, if your engine uses a "knock sensor"... I would also advise against using solid engine mounts. Specifically if you are going to run an "LS" series engine.
MonzaRacer
02-06-2007, 03:23 PM
I have built several cars with engine plates and had solid mounts in my 70 Monte Carlo from the day I put tit together and through 2 small blocks and a big block. I still have those mounts too cause I made mine.
I have never had a problem with either big or small cams.
6'9"Witha69
02-06-2007, 03:31 PM
I use solid mounts and Poly trans mount. No problems but I have a 114 LSA Roller cam so that makes a difference at idle.
Stu Seitz
02-06-2007, 06:57 PM
I'm running solids with a lsx motor, while it is stock, it never triggered the knock sensor when it was on the dyno and it has never once thrown a trouble code. Nock sensors can also be desensitized.
camaro608
02-06-2007, 07:01 PM
hell id do it
fotoboy
02-06-2007, 09:43 PM
solid on last car, motorplates on current, not a prob, cars cooler shaking at idle imho
