View Full Version : compression guess??
SicMonte
01-02-2007, 05:36 PM
I have a sbc...with 64cc vortec heads...a "thin" head gasket with .038" compressed height...and flat top pistons with 4 valve reliefs.
I got some new heads...Dart Iron Eagle 215's...with a 72cc chamber...and a "normal" height head gasket. The same pistons will be used...
Here is the question...I want to run a weiand 144 blower on this set up with the dart heads...will I have too much compression?? Im not sure of the compression numbers with these set ups. What do you all think??
eville
01-02-2007, 08:37 PM
Here's a link to Pat Kelley's article on dynamic compression. and a link to his compression calculator at the bottom of the linked page.
http://www.empirenet.com/pkelley2/DynamicCR.html
With this you'll be able to calculate your static and dynamic compression ratio. I think you'll need a dish piston with that blower, but I'm no expert in about forced induction.
Good Luck.
SicMonte
01-02-2007, 09:52 PM
man thats a lot of work
