View Full Version : fuel fittings AN NPT and ?
TheRoaringEagle
01-21-2007, 11:36 PM
hi, i was figuring out how to put my fuel line together from fuel pump to carb. so far i bought a bunch of pieces i don't need. i'm having trouble with the fuel pump. it's stock and it was using a 3/8" line to rubber hose, to filter, to hose to carb.
i was wondering what size fitting was on the fuel pump. i foolishly ordered some -6 an to 3/8" fittings but now i realize the 3/8" npt male doesn't fit in the fuel pump outlet.
i wanted something simple but it's now a disaster. i initially wanted to bend a hardline from pump to filter using russels aluminum line, with -6AN sleeves, one connecting to a coupler that could mate the -6AN to the fuel pump outlet and the other connecting to the male -6AN end of earl's fuel filter. then adding a fuel pressure gauge adapter on the back of the filter to the russell fuel line/banjo -6AN female fitting made for edelbrock performer carbs. - well those are the parts i have.
any suggestions? i probably made it too complicated
Twin_Turbo
01-22-2007, 02:45 AM
mech fuel pump? Edelelbrock pumps use 3/8 pipe (NPT) threads
Is yours a 3/8 inverted flare? You can get o ring to an adapters from summit, jegs and others to plumb using an hardware
CarlC
01-22-2007, 01:49 PM
My Carter is also 3/8-NPT.
Find out what the pump outlet is and let's go from there.
camcojb
01-22-2007, 03:26 PM
most stock pumps use an inverted flare fitting, which is available from most any of the AN suppliers. It is not the same as NPT though as you found out; the inverted flare seals on the flare itself, not the threads like an NPT fitting.
Jody
TheRoaringEagle
01-24-2007, 02:44 AM
yes i believe my stock pump is inverted. but i was considering replacing the pump soon. for now i have 3/8" brake line and hose installed. i think i'm going to stay with this poor set up until i tune my engine correctly. then i'm going to replace the tank, line and pump.
but with carter pump i should be able to use my 3/8 npt adapters, right?
