View Full Version : Engine Help
Jeremy
05-10-2007, 05:52 PM
I was driving today and had changed shock settings and thought I would see how this affected hard braking. I hit them pretty hard and the engine died. It would not start no matter what I tried. It had done this to me the last time I braked hard but started and ran like crap. When I checked the timing the distributor had slipped retarding timing.
I had it towed home and about three hours later I was able to get it started but I had to advance the distributor as far as it would go. I have been able to back the timing down a bit but no where near where it needs to be. I have it idling at about 1500 with a lot of advance but it has under 10 HG of vaccuum and it had 17 before today. I have taken the carb (Edelbrock) apart and checked the floats. The were a little out of spec, but I fixed that and everything is working.
I figured the car flooded and thus the reason it wouldn't start but I figured it would have cleared up by now. IF I turn on the AC the car can't handle the load and dies. If I lower the timing or idle speed it dies and I have to max the advance again to get it started.
I have looked for anything that could have come loose and haven't found it.
I appreciate any help as I am at a loss. I also need to car up and running for day to day use and a show this Sat. Thanks.
Jeremy
05-11-2007, 04:45 AM
Some things I can rule out are any accessory that uses vaccuum as I pulled and plugged every line coming from the engine. No change.
I ran it tody and it started right up. I let it run and the most it would pull was 6 inches of vaccuum. I am still running way too much timing but if I back it down the motor dies.
It can't take any load at all. If I turn on the AC the vaccuum drops to 0 and the motor will die in a few seconds.
If I ease the throttle open, the rpms and vaccuum will increase. If I try to open them quick, it wants to die.
Someone give me some ideas. My bet is on something internal in the carb, but I can't for the life of me guess what it would be.
I can pull a 3/8 vaccuum line and leave it off with no change. I can cover the air horn with my hand and no change.
malihoochie
05-11-2007, 05:45 AM
It would seem to be vacuum leak related, especially since pulling a vacuum line and adding a leak doesn't affect the motors running. Putting your hand on top and blocking air only adds to this thought as it seems to be getting air elsewhere. Edelbrock carbs do not have many internal parts to fall, move, or break & the vent "tubes" are on the sides of the air horn - so a sudden stop (going forward) should not cause fuel to choke out the engine.
I suggest looking on the manifold for missing or damaged vacuum plugs, hoses, etc.
malihoochie
05-11-2007, 05:54 AM
How about taking a good look at the fitting at the back of the base of the carb? It is often hard to see and may be your issue.
Jeremy
05-11-2007, 01:50 PM
I checked all the vaccuum lines and plugs and all is good there. I checked the EGR valve, removed and plugged it (wasn't hooked up anyway) and no change.
I drove it around the block today and if I kept it above 2K rpm it ran like it should, it just can't take any load under this point.
I noticed when I had the carb apart there was some sediment of some sort in the bottom of the bowls. Could this have gotten into something on the idle circuit?
When I tried to drive it, it felt and the air/fuel meter showed that it was not getting fuel. Above 2K the gauge was right at the lean/rich line where it had always been.
I had noticed that it seemed to surge a bit at low load when it should be cruising on the idle circuit prior to this, if that helps.
LS6 Tommy
05-13-2007, 09:55 AM
Sounds like you blew the diaphragm on the brake booster. Is the brake pedal any harder? If so, try disconnecting the booster line and capping the port. You might want to try it even if the pedal is the same.
Tommy
Jeremy
05-13-2007, 12:03 PM
I've pulled and capped the line, no change.
I put on a new fuel filter and PCV today. No change. I put on a new Edelbrock 600 CFM carb (750 originally). Once I got it started I was able to at least drive it. The AFR was showing max rich at low engine speed. Once the car got going, it actually ran fairly well, just not much vaccuum although it got better the longer I drove it.
For the most part the AFR was very rich throughout all situations which struck me as odd as the carb was much smaller than what it replaced. At least with the smaller carb the AFR would come off of max rich.
05-13-2007, 10:27 PM
Try a compression test on a few cylinders.
I'm wondering if you had the cam timing slip or perhaps the cam to distributor gears jumped a tooth. The GM nylon tooth cam sprockets get brittle and break with age, what shape is yours in? I'm not sure how hitting the brakes would cause it but something happened!
David
Jim Nilsen
05-14-2007, 05:34 AM
I'll second the timing problem and it being the chain. Get out the timing light and see what you get?
Jeremy
05-14-2007, 03:37 PM
I pulled the intake to reseal it figuring it was relatively cheap and found that the bottom of the intake manifold had a 3 inch crack in it. I am betting that the crack is the cource of the vaccuum leak.
I also think that the intake gaskets were leaking a bit as well as I spray carb cleaner along the gaskets before pulling the intake and the engine speed picked up. Several spots on the gaskets were wet leading me to believe that the gaskets may have been leaking and the carb cleaner got pulled in.
The new intake will be here in a few days and hopefully that will take car of everything.
Jeremy
05-16-2007, 02:08 PM
The new intake did not fix the problem, although I am happy to have one without a crack in it.
I pulled the distributor and found that the mechanical advance could not move. I could not get it to move with a hammer. It was rusted solid. When I started to disassemble the distributor to try and fix it it was missing a tanged washer on the bottom as well.
The shaft also had a lot of resistance to spinning so I ordered a new distributor and it will be here tomorrow.
Just to make sure, on replacing a distributor, you turn the motor over by hand until you feel air coming out of the #1 cylinder and then keep going until the timing mark is lined up, correct? This should be top dead center, right?
I know it is a simple question, but I want to make sure. This is how I staged the motor for the new distributor.
evan
05-16-2007, 11:10 PM
...Just to make sure, on replacing a distributor, you turn the motor over by hand until you feel air coming out of the #1 cylinder and then keep going until the timing mark is lined up, correct? This should be top dead center, right?
I know it is a simple question, but I want to make sure. This is how I staged the motor for the new distributor. I don't have an answer for you, but I hope someone does. With all that persistence (and money) you deserve to have this work for you.
Jeremy
05-17-2007, 11:11 AM
I replaced the distributor today and it fired right up and the timing was in the range that it should be. It idled very rough and would backfire through the carb.
From what I have read about through carb backfires, I am geussing that this means I have a valve problem or problems? I would assume a stuck valve would contribute to the low vaccuum.
Any thoughts?
Jeremy
05-17-2007, 12:36 PM
I advanced the distributor and it idled smooth at 1250 but still only pulled 7 - 10 inches of vaccuum. I was able to drive it around the block and it didn't drive bad considering there is something wrong. The AFR is fine at idle, and then dances around a bit while driving. I know it is a little lean on the primary side given the smaller carb and I haven't jetted up yet.
It backfired out the carb twice while I drove it but I don't know if that was because it was lean or not. When I let off the throttle with it in gear the vaccuum will jump to 15 to17.
I am going to do a compression check next as I can't think of nothing else to check.
I tried a can of sea foam as I figured it couldn't hurt at this point. It seemd to smooth things out but no change in vaccuum.
Here is what I know to this point.
The carb is new
The intake is new and sealed properly
The distributor is new and installed as it should with the motor at TDC
Vaccuum is too low
The motor only runs with a high amount of initial advance
The motor turns slow when warm but will start. This seems consistent to me with a motor running a lot of advance.
The motor actually runs smooth at higher rpms. A vibration I had before is no longer noticeable.
The motor doesn't make any odd sounds.
The problem started when I slammed on the brakes and the motor died.
Come on guys, there are a bunch of knowledgable folks here and someone has to have some thoughts.
Vegas69
05-17-2007, 12:59 PM
Do a compression check as suggested. I also like the suggestion of the timing chain.
JEFFTATE
05-17-2007, 01:19 PM
Check Cam timing.
Do a compression test.
Do a leakdown test.
Jeremy
05-17-2007, 01:22 PM
I found a timing chain test on line that said to watch for rotor movement while turing the motor the opposite direction. According to the article one should see the rotor move in 3 to 5 degrees.
Doing this I checked mine twice and got 14 degrees of movement on the first test and 18 degrees on the second test.
Am I safe to asume that the timing chain is stretched and causing the problems?
The timing chain in the motor is an unknown brand that came with the PAW rebuild kit. The local Oreilly's can get me a Cloyes heavy duty set for a good price. Is Cloyes a good brand?
In further reading on stretched timing chains, I found that this will cause low cylinder pressure in all cylinders which I believe should lead to the consistent, steady low vaccuum reading I am getting.
Jim Nilsen
05-17-2007, 07:36 PM
Yes Cloyes is a good brand and 18degrees is way too much for a chain and is probably worn a nice line in your timing cover. I had one once that wore a line that started to leak before it decide to jump time. This is a common problem.
Jeremy
05-17-2007, 08:33 PM
I'll find out this weekend as I the timign set will be in tomorrow and I hope to have some time here and there to tear into it.
I believe the set I ordered as three settings for 4 deg advance, straight up, and 4 deg retarded. What does everyone recommend to set it at.
I was thinking the 4 deg advanced might be a good idea. I have 6x heads with a 068 cam and I think it is a little low on compression and cylinder pressure. I have always had to run a lot of initial advance on the combo and think that the 4 deg would help.
05-17-2007, 10:14 PM
Advancing will bring peak HP at a lower rpm, not a lot but maybe 500 rpm's lower. Be very careful indexing the crank sprocket. The symbols Cloyes uses is a triangle, square and "O". The O and square can get mixed up fairly easily. I had a buddy with a new engine that they installed the gear with square on the keyway, but indexed off the "O" on the tooth, it ran terrible, got up to 3000 and fell flat on it's face.
I hope you didn't bend a valve, do a compression test or better yet do a leakdown test after you get the new chain on the car and don't turn the crank much without the cam turning or you can bend a valve that way. If you do have to turn the engine farther than it takes to get the gear on, back off the rockers first.
David
rohrt
05-18-2007, 06:46 AM
I would ask on a pontiac site weather or not to change the index. I would say leave it strait up but I'm sure it depends on Engine, Mods and how you plan on driving it.
rohrt
05-18-2007, 10:29 AM
http://www.thepontiactransampage.com/engineblueprint.html
I happended accross this page. It talks about installing the 068 cam for performance. Many other things mentioned that relate to this post.
Jeremy
05-18-2007, 02:57 PM
I got the front of the motor pulled apart today and the chain has more than an inch of slack in it. The dots on the sprockets show that the cam is about 20 degrees retarded.
The crank dot is at the top and the balancer mark was at 0 when I pulled things apart. At least this was spot on.
Thanks for the pontiac website, it had a lot of good info. One person on a pontiac board recommended straight up, but the link you gave makes 4 deg advanced look real good, although it will probably put me closer to detonation.
It took less than an hour to strip the front of the motor, but it will take a lot longer to put it back together. Since it is apart all the pulleys, accessories, brackets, etc will be re finished.
MonzaRacer
05-18-2007, 08:18 PM
I like Pontiacs and for the record I would use the 4 deg advanced as it will give you more lower end torqe as it will build cylinder preasure.
Get the engine up on # 1 and set the timing at the 12 to 14 intial timing.
I like to use stock advance weights and then swap in lighter springs till you get the curve all in by your cruis RPM, this works best if you can source an advance type timing light.
With a advance curve kit I never use the new weights or plate. With 6X heads you need all the help you can get I would also go back to the 750 if its ok.
I then get my mixture set in drive idling then hook up your vacuum advance to manifold vacuum and then reset your idle speed in gear and readjust the idle mixture too .
Then give it a drive i will bet you will love it.
As long as your not spark knocking and its pulling hard your not gonna hurt a Pontiac, Drove mine this way for over 5 years and got some great mileage too for my full size car.
The 6X is an open chamber head with good flow and very efficient chamber and since all Pontiacs have machined chambers they are very knock resistant.
Any questions pm or email me at [email protected].
Good Luck
Lee Abel
AFTERMARKET PERFORMANCE
Jeremy
05-18-2007, 09:32 PM
I got the timing set today and it is not a three way set. I am not sure if I will take it back and order a three way or not.
As for carbs the 750 is good, just dirty. I'll probably try the 600 for a while and see how it does. I checked all of the CFM calculators and according to the formulas is is plenty big. I understand that they are guidelines, but I hope to pick up some throttle response and gas mileage. Of course I realize it won't be a fair comparison as the 750 was running on a loose chain.
rohrt
05-21-2007, 05:30 AM
You may want to consider going back to the Q-jet if you are wanting a little better milage and still keep your power. The Q-jet is kind of like wearing a Mullet. Buisness in the front and party in the back. Nothing wrong with using a diffrent carb but it sounds like a Q-jet would work well with your application. I had a 600CFM on a 400 a long time back and it ran great, instant throtle response.
rohrt
05-21-2007, 05:36 AM
Funny I just ran into your other post about the carb. Didn't realize it was and Edelbrock. It is the worst carb in the world IMO. I had a 750 with a calibration kit and tried for a long time to get it work well. Never had any luck. My brother and I both sold our on Ebay. If your is a newer one with the quick tune feature then thats a diffrent story. My .02 cents is still with a q-jet and find out from someone who has dialed theirs in and use the same rod/jet combo. Then all you have to do is set the idle screw and the sencondary flap opening and run it like you stole it.
Jeremy
05-22-2007, 11:00 AM
I would love a Cliff built q jet but this little fiasco has used up all of my car money for the summer. I've been pretty pleased with the edelbrock carbs so I'll see how that goes once everything is back up and running.
I pulled the old set today and realigned the cam. I think I should be in great shape. When I went to line up the dots I used a level and it hit the dots and the center of the cam perfectly and the level was spot on verticle.
Hopefully by the middle of next week I will have it running. It is taking longer to get everything prepped to go to the paint shop and I am still waiting on some new dress up items anyway.
I would hit it this weekend but I have to go to the in laws.
malihoochie
05-22-2007, 02:25 PM
I think you'll be back in business in no time.
Jim Nilsen
05-23-2007, 06:53 AM
You will think you have a totally different car!!
Power will be up ,throttle response will be crisp and your mileage will be lots better too!!!
Have fun, you are now close so don't go changing too much until it is telling you to replace it still.
Jeremy
05-23-2007, 09:35 AM
I don't plan on replacing/changing anything else. I just can't believe how much was in poor shape, particularly since I rebuilt the car 6-7 years ago. Of course, that is the risk you run with rebuilding old parts.
The fact that the car ran halfway decent with a froze distributor, cracked intake and stretched timing chain is amazing.
I got all of the pulleys and brackets stripped today and will drop them off at the paint shop this afternoon. I had painted them with rattle can and they looked okay. I am going to have them shoot them with some better paint at probably 80% gloss. It should make things look much nicer.
With the new intake, new carb, new distributor, chrome waterneck, new chrome valve covers, and fresh pulleys and brackets the motor should look great. Off course I am painting the waterpump housing and the front of the block as well.
Jeremy
05-29-2007, 02:47 PM
Its alive!!!
Thanks to all those that helped. I got it put back together today and it looks great and fired right up once gas got back to the carb.
I really like the 600 carb around town. It is much more responsive. It is also a lot more responsive to metering rod changes.
I also pulled a while I was at it and got new chrome valve covers, chrome water outlet, and had the body shop repaint all of the pulleys, brackets, etc. It looks better than before.
