View Full Version : Suspension
- aftermarket frames (1 replies)
- Fatman NARROWED uca's?.. anyone running them? (17 replies)
- Got my AFX spindles!!! (4 replies)
- Unique Performance rear suspension (3 replies)
- 69 Camaro - rag joint sources (1 replies)
- C5 front clip frame? (5 replies)
- Anybody running a great setup for A body Chevelle? (27 replies)
- Strong and safe enough? (18 replies)
- Dumb question, but I'll ask anyway. (2 replies)
- Tubular UCA header interference - crap, crap, crap!! (12 replies)
- 55 chevy ifs kit (0 replies)
- complete suspension, 71 camaro (14 replies)
- 1970 Mustang suspension (9 replies)
- panhard bar mounts (4 replies)
- drag-race style ladder bar setup for handling? (8 replies)
- Which Rear springs for c4 IRS (7 replies)
- Schwartz Full Chassis Q's. (24 replies)
- ford suspension help! which coil over kit to use? (7 replies)
- art morrison clip (0 replies)
- Pinion angle (4 replies)
- Polyurethane Bushings (7 replies)
- anyone used suspension package from Hotchkis for 70-73 camaro (5 replies)
- 1980 Malibu, Stance Help (7 replies)
- Ididit Column (2 replies)
- McQuay Norris Ball Joints (8 replies)
- AFX vs CW (13 replies)
- Solid Control Arm Bushings (9 replies)
- Any one else making a 2nd gen tub kit? (10 replies)
- 'bu wagon spring rates (9 replies)
- 77 T/A Suspension Setup (24 replies)
- Chicane-LM front suspension package from ATS (2 replies)
- front wheel not centered in opening (8 replies)
- Will DSE springs work for 1/4 mile (5 replies)
- Suspension geometry terminology (3 replies)
- anyone heard of Fatrodders Rod Parts (6 replies)
- Average price of an AirRide setup for a first gen? (5 replies)
- Circle Track UCA's on an A-Body (8 replies)
- manual steering box (8 replies)
- solid UCA bushings w/ zerks (3 replies)
- input on quick ratio steering box? (8 replies)
- Some suspension Q's from a new guy with a g body (2 replies)
- Experience with centerdrive or truckarm rear suspensions (5 replies)
- Remote Reservoir PS Pump Question (5 replies)
- Tall spindle for an 58-64 Impala? (4 replies)
- Coil spring delema. Funny! (8 replies)
- Rack and Pinion conversion....? (4 replies)
- Air Ride Questions (2 replies)
- Miata/MX5 front uprights/brakes?? (0 replies)
- Cheap mini tub???/question on brake setup. (12 replies)
- Cheap mini tub???/question on brake setup. (2 replies)
- Anyone have pics of 69 camaro w/ 3" drop DSE springs? (11 replies)
- C5 Corvette concentric (2 replies)
- Another First Gen Subframe (Not Pro-Touring Though) (4 replies)
- Anyone had any experience with Schwartz Engineering full tube chassis? (1 replies)
- Finally decided (4 replies)
- What shocks should i go with? (8 replies)
- 68 GTO front suspension questions (5 replies)
- Caltracs (3 replies)
- XV Motorsports Level One Suspension Info (9 replies)
- Subframe X-member sag (3 replies)
- A big tip for anyone using the Hub/beaing from vettes (1 replies)
- To those with the TVS (6 replies)
- steering shaft (1 replies)
- 4 link (0 replies)
- nova rear suspension?? (6 replies)
- Z06 wheels on a 68 Camaro (0 replies)
- 66 chevelle rear suspension (4 replies)
- Thanks SC&C (1 replies)
- 2" drop spring problem (0 replies)
- New member with some questions (0 replies)
- Rag joint replacement (2 replies)
- Body dropping a 68 Camaro (18 replies)
- g-brace or firewall strut (5 replies)
- Shake-down cruise ??? (2 replies)
- Subframe bushing install questions (2 replies)
- Lateral effects (18 replies)
- Another engineering question (2 replies)
- Axles..which manufacturer (7 replies)
- Wayne Due C4 alignment (5 replies)
- Will cutting a coil spring change anything? (2 replies)
- Sway bar construction theory (13 replies)
- tubular control arms equal larger wheel on f-body? (2 replies)
- Hotchkis A-arms finally released (4 replies)
- Rear Sway Bar? (2 replies)
- Ford 9" Housing Width (0 replies)
- swaybar angles?? (11 replies)
- Alignment question - not exactly Pro-Touring. (8 replies)
- subframe bushing: poly or aluminium? (12 replies)
- Torsion style anti swaybar (2 replies)
- BRP r&p steering for 1gen. Pros and cons ?!?! (4 replies)
- Hotchkis or Eibach springs? (6 replies)
- DSE vs Air Ride (36 replies)
- Suddenly I find myself extremely angry. Air ride guys, need advice. (1 replies)
- Suspension ?s (5 replies)
- Second Gen Camaro Coilovers (6 replies)
- Rear sway bar (3 replies)
- mini-tub pictures (4 replies)
- adjustable spring shims (3 replies)
- mini tub with leaf springs (5 replies)
- What front springs for a 1970 chevell w Ls1 swap (1 replies)
- Where to get panhard rod made or parts (4 replies)
- Rear Leaf Springs (13 replies)
- Need help with a Ford 9" rearend (1 replies)
- How good will it handle with these things? how good are leaf springs? (4 replies)
- Struts on '67 Mustang (9 replies)
- Has anyone made their own aluminum power steering reservoir? (8 replies)
- Shock recommendation (55 replies)
- Dana parts (0 replies)
- Dropping a 71 Camaro (13 replies)
- Older power stearing box with LS1 pump (1 replies)
- Dse Wheel Tubs (0 replies)
- internally threaded LH/RH adjusting sleeves (15 replies)
- Prolly one of the dumbest questions ever... (3 replies)
- Modification of Leaf Springs (1 replies)
- Needs some help - Shortening 9" rear-end (9 replies)
- Front Coils Rubbing on 78 Nova (9 replies)
- Air Ride Tech users, in here Please! (7 replies)
- Wayne Due c4 copy cat (4 replies)
- Any companys make an IRS kit for 1st gens? (8 replies)
- 4 links (0 replies)
- Thinking of back-halfing my car........ (0 replies)
- martz chassis rear setups (1 replies)
- Scored on a new front swaybar (G Body) (3 replies)
- Need advice, Clueless..... (3 replies)
- Power Steering Conversion For 375?? (0 replies)
- lowering block problem with shock plate? (11 replies)
- Opinions wanted (22 replies)
- Suspension with a budget in mind... (6 replies)
- chassis brace (4 replies)
- I'll Beat the horse some-more! (47 replies)
- Convertible body pan for coupes? (1 replies)
- C4 IRS measurements in a 69 Camaro (10 replies)
- C5 drivetrain/suspension in 1st gen?? (9 replies)
- reverse air ride (8 replies)
- DSE mini tub and gas tank change (6 replies)
- Fat Man Fab 2" Drop Spindles for Chevelle (7 replies)
- DSE 4-link (1 replies)
- DSE minitub for 68-72 Nova (1 replies)
- Spring recommendation for 2nd Gen Z28 (3 replies)
- braided hose for power steering? (23 replies)
- Coil cuts (8 replies)
- 1st gen weight distribution. (4 replies)
- half shaft failure... (4 replies)
- "Tri" angle four link???? (8 replies)
- DSE 2nd Gen Mini-Tub Kit--Opinions-- (9 replies)
- Help with rear suspension on first gen (firebird) (4 replies)
- ATS boys--it's time for my monthly nagging... (3 replies)
- DSE LCAs with Hotchkis front sway (2 replies)
- VBP transverse spring (1 replies)
- what type of suspension for 69 bird (11 replies)
- Spreadsheets (0 replies)
- Chevelle Rack & Pinion offered (18 replies)
- Should I use a rear swaybar? (10 replies)
- Mustang Air Ride? (24 replies)
- 1st gen camaro subframe - same as firebird? (3 replies)
- Savitske ball joint and offset shafts (2 replies)
- Assymetric Steering Effort (1 replies)
- Chevelle Triangulated 4 link (16 replies)
- Pontiac B body front suspension (54 replies)
- Steering shaft- major problem. (3 replies)
- 2" or 3" drop in rear? (0 replies)
- gen 2 tilt colum in gen 1 69' camaro (1 replies)
- Ok, finally ordering some coilovers (7 replies)
- Is This A Bigger Problem....? (12 replies)
- Positioning front links on a C4 IRS (0 replies)
- 79'Trans am rear suspension advice (10 replies)
- Mounting front springs (1 replies)
- Anyone ever done (6 replies)
- 72 Nova Front Suspension Questions (3 replies)
- Air Ride Pro (4 replies)
- Need help getting front suspension back together (4 replies)
- Anybody installed GW body mounts? (4 replies)
- Looking for custom offset splined swaybar arms (2 replies)
- coil springs or airbags? (23 replies)
- What front subrame is right for chevy II (3 replies)
- Chevy II leaf spring rear questions (3 replies)
- Sway bar for Wayne Due C5 frame? (5 replies)
- Aftermarket springs sagging prematurely? (6 replies)
- best frame replacement for 65 elcamino (2 replies)
- 4 link (4 replies)
- Idler arm bearings? (2 replies)
- Better straightaway feel (12 replies)
- Torque arm for 68 camaro. (5 replies)
- Question on leafs and Cal Tracs (6 replies)
- C5 IRS with standard driveshaft?? (2 replies)
- S60 rear (2 replies)
- Jim Meyer Racing Products (0 replies)
- Rear Leaf Springs on a First Gen (4 replies)
- cut springs ? (12 replies)
- 71 F-Body Front Suspension Kits?? (0 replies)
- Tire Clearance? (3 replies)
- GW Springs and Competition Engineering Bars (3 replies)
- Camaro 2gen Rack and pinion (3 replies)
- DSE Coilovers camber difference right to left (14 replies)
- Stuck ass Pitman arm (4 replies)
- 67 rear suspension (7 replies)
- Proper setup of leaf spring rear?? (10 replies)
- AME full frame (4 replies)
- 65 mustang front suspension (21 replies)
- 4th gen rack and pinion, who is running them ? (4 replies)
- Nuts and Bolts Question (10 replies)
- total cost involved's front and rear (50 replies)
- Hub centric vs lug centric rear axles (6 replies)
- Anyone using 04-06 GTO suspension (1 replies)
- Setting up a 4 link (4 replies)
- nova engine mounts (7 replies)
- Air Ride? (1 replies)
- Boxing A-Body Frames (8 replies)
- Need help with rear spring measurement (2 replies)
- AFX Spindle Update for 2nd Gen F-body?? (46 replies)
- 77 TA-2nd Gen Suspension suggestions (25 replies)
- AFX spindles on 68 camaro (15 replies)
- c5 subframe!!! (6 replies)
- G-braces 2gen. Camaro (27 replies)
- adjustable control arm broke again! (14 replies)
- shock angle / position (3 replies)
- Recommendation for minitubbing and fab work in Seattle area? (9 replies)
- which drop spindle? (7 replies)
- G-body: Wrong parts, or am I just a dumb azz... (17 replies)
- Floor mounted E-Brake in a G body ?? (1 replies)
- JAG IRS opinions? (4 replies)
- Corvette Suspension Dimensions Needed (53 replies)
- Ride Height (2 replies)
- 17X11 TTII's on mini tubbed 67 camaro (6 replies)
- Which shocks? (19 replies)
- Paging ATS.... (24 replies)
- 8.25" Mopar disc brakes? (4 replies)
- Lateral-Dynamics 3 Link (12 replies)
- Leaf spring bushings (1 replies)
- replace trunkpan first? (4 replies)
- Rear roll steer ? (2 replies)
- 71 A body Questions (0 replies)
- Heidts New 4-link kit (7 replies)
- Rear Suspension; Pan hard, sway bar, neither. Help? (0 replies)
- G-body Spohn rear sway bar on SCandC.com (91 replies)
- 68 Camaro QA1 lowering kit (3 replies)
- What do sub frame connectors really do... (96 replies)
- Lower Tubular control arms (5 replies)
- AGR steering box/pump? (4 replies)
- AFX spindels and ABS (7 replies)
- DSE front coil over conversion (12 replies)
- Body Bushings (15 replies)
- B-Body Spindle Swap ???'s (20 replies)
- Chris Alston Camaro Clip???? (1 replies)
- Mopar suspension input needed (9 replies)
- Oem front LCA part#'s? (0 replies)
- tci 67-69 camro subframe (2 replies)
- rear lower control arms (0 replies)
- Shock Lenght ? (6 replies)
- spread sheets?? (2 replies)
