View Full Version : internally threaded LH/RH adjusting sleeves
jerome
12-03-2006, 01:32 PM
i'm looking for hex or round tube that is internally threaded 3/4"-16. One half needs to be RH and one half needs to be LH for adjustment. I need 4" and 6" length. It can be either t6 aluminum or steel. These are for adjustable control arms. Afco has it, but the shortest length is 11". SPC has them for their control arms (i'm building arms that are very similar) but they are unreasonable expensive.
Does anyone know where I can find these? i would fabricate these but a 3/4 LH tap is 35$.
thanks,
Jerome
nowukno
12-03-2006, 01:35 PM
thanks,
Jerome
You could try Coleman racing..
jerome
12-03-2006, 01:48 PM
looked at their catalog and it wasnt listed, sent them an email about it.
thanks, anywhere else i could look?
Jerome
Davezz28
12-03-2006, 03:04 PM
Try these guys
http://www.midwestcontrol.com/catdisplay_short.php?pg=207
pav8427
12-03-2006, 03:53 PM
Check with speedway, I think you order by the inch
12-03-2006, 08:52 PM
Links do help people!!
they are listed as trailing arms on the coleman web site...check the diameter. -10" lengths on the last page.
http://www.colemanracing.com/catalog/index.php?cPath=49_722
DusterRT
12-03-2006, 09:45 PM
Try these guys
Those are made of 6061 (edit: corrected; not T6..) but have no heat treatment; not sure if they would be suitable for control arms as-is or not.
jerome
12-03-2006, 10:06 PM
oh i see, i will call coleman and ask if they will make them shorter, or if they have enough thread to be cut down to length.
still looking for alternatives taht are the correct length already though.
thanks
Hidro
12-03-2006, 11:44 PM
thanks
If you clicked page 4 on mr quicks link you would see what you wanted. 4 inch and 6 inch
:twothumbs
jerome
12-04-2006, 10:53 AM
yeah, found it on coleman's page. thanks for your help guys. i ended up ordering from spc performance cause they had steel for $11, and i found out that I only need the 4" ones.
Jerome
Hidro
12-04-2006, 11:17 AM
Jerome
Coleman has 4" steel ones for $7.70 in case you didnt see them.
cya:santa3:
jerome
12-04-2006, 12:40 PM
damn, i suck at finding stuff on their page. well, my wallet is 12 dollars lighter than it would be i guess.:guilty:
now i gotta go on mcmaster and order some left-hand rod.
here it is if anyone else was looking for them:
http://www.colemanracing.com/catalog/product_info.php?cPath=49_723&products_id=2962
Jerome
12-04-2006, 09:07 PM
Those are made of T6 but have no heat treatment; not sure if they would be suitable for control arms as-is or not.
T6 IS a heat treatment.
2024, 7075, or 6061 would be the alloy.
DusterRT
12-04-2006, 09:16 PM
My mistake! They are 6061, no heat treatment. I blame the long weekend...:scared:
12-04-2006, 11:16 PM
Most 6061 is either T4 or T6, I don't think there is any made with no heat treat but I'm picking nits here, I would like to add that I prefer steel parts for suspension links, especially when threads are involved.
Good luck with your project.
David
DusterRT
12-04-2006, 11:55 PM
Well, I was thinking about making some links up out of that stuff from Midwest Control a couple months ago. I called them up to ask their tech guy about the particular alloy and what not, and he stated they were 6061 with no heat treatment whatsoever.
My calculations showed they would have been strong enough for my application despite the lack of HT, but the 6-8 week wait for them to make some didn't work out so well, so I modified stock links..I was concerned about how well the threads would have held up though. I looked into heli-coils but didn't come up with much for left hand threads; but then again I didn't look all that hard either due to the availability issue nixing the project.
