View Full Version : S60 rear
Olav
10-28-2006, 04:49 AM
S60 axle is the same as dana 60 or what is it mounted on? Is it Special Strange housing?
Olav
peacemaker
10-30-2006, 06:05 PM
The S60 is Stranges answer to a stronger aftermarket rear for hard big cube, big torque, sticky tire usage. It is essentially a Dana 60 with welded axle tubes and available with a whole host of options. It can be ordered to bolt into GM A & G-body's with a four link rear suspension. It can also be ordered to fit GM's F-bodies. They have centers from the TracLok to a spool and drum brakes to a custom Baer set up. If you have the coinage you can order a virtually indestructible rear end to your door completely set up and ready to rock! I can't wait to put one in my Goat!
go-fish
10-30-2006, 06:19 PM
If you can have it shipped to a business it is cheaper for shipping, you're going need a forklift to get it off the truck anyway. They don't do UPS either. I got mine sent to my buddy's body shop, ended up being around $2,400, that's without the Willwood kit. They were a BEEEAATCH to put on. They come with all different kinds of axle bearings and they can set it up for just about any application, i.e. ford, shivvy, mopar. I got the reinforced aluminum rear cover on mine and had it shortened 2".
