View Full Version : swaybar angles??
jigga99
12-16-2006, 04:14 PM
i put in a 1 1/4 swaybar in, and the back of the sway bar towards the back of the car, is were it bolts to the lower a-arm, its angle is quite steep from lowering the car, will this harm the performance of the bar? do i need to cut the sleeve spacer? so i guess my question is should the bar sit level?
hotroddr
12-16-2006, 05:30 PM
yes it should sit level
boodlefoof
12-16-2006, 05:32 PM
Seems to me that if the bar isn't level (i.e., the arms are pointing up or down) that this would effectively reduce the length of the arm and thereby increase sway bar rate.
baz67
12-16-2006, 05:52 PM
That is not a good thing. You want them level to the ground. These will help. http://www.guldstrand.com/link.htm
nowukno
12-16-2006, 07:10 PM
OOps wrong quote!!
nowukno
12-16-2006, 07:13 PM
Hey buddy,were can I find these,and will they work with the standard after market front sway bar,you know the ones that use the common endlink with the 4 bushings and middle sleeve..These links look awesome.You using them?
baz67
12-16-2006, 08:13 PM
www.guldstrand.com The original link was from the Corvette section, but the Camaro section has them as well. I would say they will work as long as they are long enough in your application.
IIRC, ATS also had some in the works. Now with everything else on their plate who knows if they will get them done.
12-16-2006, 11:39 PM
Keep the links a little bit on the long side for a first gen Camaro. They also swing side to side on the bottom end when the lower A arm moves up and down. If they get too short, they will pull sideways on the bar and create a bind. If you have conventional polly bushed end links, don't over-tighten them, especially if the anti-roll bar arm ends are not level, it will bind. It's the eye end of the arms that matters.
jigga99
12-17-2006, 11:16 AM
good info thanks
chicane67
12-17-2006, 05:32 PM
Use of the 63-82 Corvette end links will solve this issue.
Energy Suspension part number: 9.8120
jigga99
12-18-2006, 12:08 PM
its winter here right now so, ill let you know how it rides in 3 months hahahaaha
6'9"Witha69
12-18-2006, 12:19 PM
My local Autozone has an array of different length Energy suspension endlinks, as I think most autoparts stores do. Just measure and find the right length. As Dave suggests make them a little longer and do not overtighten.
