View Full Version : Lower Tubular control arms
PRRC
10-04-2006, 04:09 PM
Well Guys I need alittle help.We just recieved our lower Tubular control arms. At fist glance they looked just fine,until we noticed there were no sway bar mounting points? So we call Mfg. only to find out they are not in the design.seems they should be considering it did have a factory sway bar.So we started looking at some other Mfg. for the same car.No one puts them on. Theres not alot of options for a 62 Impala. So I guess my Question is this, Were can I get some tabs to weld on for a sway bar.Ive looked around today but didnt come up with much. Thanks Tim
ProBell
10-05-2006, 02:58 AM
Take a look at S+W Race Cars they have a lot of fabrication parts.
http://www.swracecars.com/ Randy
darren@ridetech
10-05-2006, 08:17 AM
We have some as well....
http://www.ridetech.com/productinfo/brackets_2.asp
This is the same tab we use on our StrongArms for that car.
PRRC
10-05-2006, 09:13 AM
Thanks Guys. I cant understand the logic behind not having them on there. Any way Thanks Again Tim
10-05-2006, 06:53 PM
These guys have loads of brackets:
http://www.aa-mfg.com/pdshop/shop/
ProBell
10-06-2006, 01:11 PM
Wile we are talking about A-arms thought I would let you know I am having a problem with my Heidts lower arms
They are sliding back and forth on the urethane bushings. I do not know if this is a common problem or if I am pushing them to hard. ( I have Bent accused of doing this to things in the past)
Plan to go to solid bushings this winter. That will make the hole car solid mounts and bushings. Randy
