View Full Version : Disc Brakes
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19
  1. Rate my brake system (and do I need a metering valve?) (2 replies)
  2. Tuff stuff vs DSE brake boosger (3 replies)
  3. Wilwood proportioning valve question (3 replies)
  4. C4 brakes (3 replies)
  5. DSE Booster or Hydratech (Dilemma) (5 replies)
  6. Making the 11-14 S197 ABS work standalone (2 replies)
  7. C6 bearing for mk60 (2 replies)
  8. brake pedal bell crank? (0 replies)
  9. C-10 rear disc conversion (1 replies)
  10. Lokar park brake routing (5 replies)
  11. Proportioning valve leak (3 replies)
  12. poor mans rear disc conversion, GM A-body (17 replies)
  13. What size plug for this prop valve? (1 replies)
  14. A Body - rear disc conversion, have question running rear line(s)?? (6 replies)
  15. Spongy brakes - 4th gen F-body swap onto 68 Cutlass (28 replies)
  16. G-Body Rear Brake Options (4 replies)
  17. Dumb ABS Question? (2 replies)
  18. Noisy brake pushrod? (0 replies)
  19. Wilwood 6 piston setup for 1973 Camaro (1 replies)
  20. Anyone mess with the electric brake booster set ups? (14 replies)
  21. Baer brakes w/ Baer or Wilwood Master Manual Setup (5 replies)
  22. Dual line brake clamp (4 replies)
  23. ABS wiring ideas/help (2 replies)
  24. Manual or Vacuum boosted brakes on 69 Camaro? (25 replies)
  25. 1st gen brake cooling duct backing plates? (0 replies)
  26. Single vs Dual Circuit Proportioning Valve (2 replies)
  27. Major Hydro boost issues (6 replies)
  28. Machining a Solid Drum-in-Hat Rotor Down into a Rotor Hat (4 replies)
  29. Why wouldn't you choose larger caliper pistons? (2 replies)
  30. Crazy Idea: Using a Brake Disc a Bolt Pattern Adapter (1 replies)
  31. Hydroboost Free Play (2 replies)
  32. C6 brakes (12 replies)
  33. Custom Braided Brake Lines - HEL Performance (3 replies)
  34. 68-72 chevy a body hydroboost bracket (2 replies)
  35. Aftermarket ABS (5 replies)
  36. Are LS1/C5 rotors the same thickeness (1 replies)
  37. Looking for master cylinder recommendations. (1 replies)
  38. 2019 ZL-1 brembos on a 1st gen (12 replies)
  39. Need whole new brake package for 1970 A-body, looking for input (26 replies)
  40. 1st Gen Firebird / Camaro 5th Gen Brake Booster Adapter bracket for SS Brembo Brakes (1 replies)
  41. Need some help with hydro-boost issues (1 replies)
  42. Baer SS4 Sticking (6 replies)
  43. CTS-V/ ZL1 Brembo wheel fitment (10 replies)
  44. Brake proportioning (5 replies)
  45. LS style PS reservoir for Hydroboost and R&P... (4 replies)
  46. C5's on a 76 TA (2 replies)
  47. Hydroboost Help (9 replies)
  48. Hydroboost vs power brakes lsa (7 replies)
  49. BAER 6P Specs (7 replies)
  50. Hydroboost Power Steering Flush (2 replies)
  51. '56 Chevy Apache with '87 corvette bits (3 replies)
  52. Master Cylinder Bore Size (2 replies)
  53. OBS Chevy CTS brakes kit? (2 replies)
  54. Do I need to shim my calipers? (1 replies)
  55. hardline hydroboost return (6 replies)
  56. Feedback on Brake plans (2 replies)
  57. Two proportioning valves or one - what was I thinking? (3 replies)
  58. Corvette C5/C6 rear bearing hub without snesor? (2 replies)
  59. Baer T4 caliper clearance (7 replies)
  60. 1 1/8 Master sizing up new piston caliper size (7 replies)
  61. Big BAER brakes on a 3rd gen Camaro (1 replies)
  62. Blackout series wilwood (1 replies)
  63. Brake upgrades!!! (5 replies)
  64. A body hydroboost T56 combo bracket / Universal hydroboost bracket (2 replies)
  65. Help with big brakes on a 70 Chevelle (3 replies)
  66. Steering Pump With Hydra boost Selection (11 replies)
  67. New Ridetech AFX Tall knuckle ! (0 replies)
  68. Stock height CPP C5 knuckle with GM brembo brakes (2 replies)
  69. Speedtech AFX + Wilwood Discs = wheels not fitting (4 replies)
  70. Wilwood Rear FDLI with parking brake will not center on rotor. Kit PN 140-7140-DR (5 replies)
  71. Speedtech preformed brake lines safe? (11 replies)
  72. The Brake Man F4 calipers on a Ford 9 inch (2 replies)
  73. 88-98 LS rear disc swap (5 replies)
  74. Explorer disc brakes on 9" (16 replies)
  75. First gen Camaro hydroboost or not (15 replies)
  76. 2015 Challenger Master Cylinder / Booster question (2 replies)
  77. Stock 4 wheel disc mastercylinder (0 replies)
  78. Wilwood D52 Caliper install - Torque Specs (0 replies)
  79. Touring Classic Brakes (10 replies)
  80. 1st Gen Fbody Intermediate Brake Line (1 replies)
  81. Brembo brakes on CPP C5 drop knuckle- bigbrakeupgrade.com (4 replies)
  82. Mounting wilwood under dash pedal assembly (10 replies)
  83. Baer S4 calipers, which pads? (1 replies)
  84. Help with Custom Hydroboost Brake System (2 replies)
  85. First gen Camaro brake light switch bracket (0 replies)
  86. Any benefits of a Tilton pedal box? (1 replies)
  87. Older Baer Brakes replacement part numbers (4 replies)
  88. Having a whale of a time finding a Wilwood MC Fitting (10 replies)
  89. F body brakes a body (2 replies)
  90. Emergency brake cable w/ Baer brakes and crossmember (2 replies)
  91. Dual master cylinder question (3 replies)
  92. Question on new Hydrastop system - Brakes won't release properly (9 replies)
  93. Budget 13" brake upgrade? (6 replies)
  94. Manual brakes (8 replies)
  95. Wilwood AERO6 Brakes for '69 Camaro (0 replies)
  96. Wilwood Aero6 front right locks, nothing from left. (7 replies)
  97. 5th gen Brembo bakes BUT manual!? (2 replies)
  98. Front calipers won't build pressure (18 replies)
  99. Mopar Hydroboost problem (4 replies)
  100. Which Way to Go?? (2 replies)
  101. 5th gen front and rear disc to 2nd gen F-Body....is there a kit? (4 replies)
  102. Power vs hydroboost for a cruiser (1 replies)
  103. 1°gen F-body C5 conversion? (1 replies)
  104. Brake boosters ….Single diaphragm vs.Dual diaphragm (3 replies)
  105. Brake opinions for my current plan 68 camaro C6 master (6 replies)
  106. Manual Carbon Ceramic Brakes (0 replies)
  107. What size master cylinder? (2 replies)
  108. Tuff Stuff 2229NC booster (5 replies)
  109. Help with Brakes, Wrong MC? (23 replies)
  110. Baer Classic Series brakes (15 replies)
  111. 1.25 rotor thickness parking brake calipers (6 replies)
  112. Rotor Loose on Axle Register (3 replies)
  113. Better stopping power (6 replies)
  114. Dual vs master cylinder (0 replies)
  115. Brembo calipers for c5 vette (0 replies)
  116. Rear Wilwood Kit on '77 Firebird (10 replies)
  117. Wilwood Dynalite Forged disc brake kit (3 replies)
  118. Difference in Pedal Travel Between 1" and 1.125" MC (1 replies)
  119. Question for those who installed LS1 brakes on first gens (0 replies)
  120. Rear brake supply line size (3 replies)
  121. Any recommendations on a vacuum pump for LS376-495? (3 replies)
  122. C5 conversion: Parking brake? (4 replies)
  123. cpp brakes? (6 replies)
  124. 77 trans am hydroboost swap and kits (4 replies)
  125. Baer/Wilwood disappointment (13 replies)
  126. Hydroboost to standard booster (4 replies)
  127. 72 Cutlass Brake Upgrade Options (15 replies)
  128. Summit Rear Disc Brake Coversion Kit 11" Rotors have 7/16 hole and I have 1/2 studs! (3 replies)
  129. C5/6/AFX Uprights + C7 Hubs + Fixed Calipers = Trouble? (1 replies)
  130. Front and Rear Rotor Sizing? (5 replies)
  131. Rear caliper bracket help (5 replies)
  132. Rear brake line Routing (4 replies)
  133. Hydroboost- quick take up master cylinder (2 replies)
  134. Right Stuff Rear Disc Conversion (7 replies)
  135. Safe, Efficient F/R Brake Bias (7 replies)
  136. C5 front caliper hose routing on 67 Camaro (3 replies)
  137. 70 Chevelle Performance Brake Upgrade Question: Wilwood AERO6 or PowerStop? (16 replies)
  138. F-body camaro disc brake conversion for a-body chevelle templates (2 replies)
  139. G-Body with C4 Calipers (11 replies)
  140. 64 Nova 11" braking performance question (5 replies)
  141. hard/spongy brake pedal (0 replies)
  142. Help me diagnose hard brake pedal (Wilwood '69 Camaro) (16 replies)
  143. Brake Wear Indicator/Scraper Orientation. Am I really wrong? (2 replies)
  144. hydra boost braking would this fit (4 replies)
  145. C6 Z06 brake caliper, can I swap left to right (5 replies)
  146. C5 master cylinder front brake line adapters question. (7 replies)
  147. wilwood 6 piston 12 vs 6 piston superlite (3 replies)
  148. Template for LS1 fbody or C6 brakes in 2nd gen F-body? (3 replies)
  149. Baer parking brake shoe won't fit over the axle flange? (1 replies)
  150. electric parking brake retrofit (14 replies)
  151. Best street pads for D52 calipers??? (17 replies)
  152. 69 camaro brake line kits? (0 replies)
  153. Brake pedal not returning all the way (12 replies)
  154. Possible to Run Wilwood AERO6 Front Brakes on 2nd Gen Fbody Stock? (12 replies)
  155. '65 GS sitting over 20 years. Spindle/brake questions. Thanks! (3 replies)
  156. C5 caliper measurements (6 replies)
  157. Help with hydroboost issues, no P/S or P/B (7 replies)
  158. Hydroboost/G-Brace Interference 2nd Gen Firebird (5 replies)
  159. Hydratech: Hydroboost Pedal Rod Swap Tips? (3 replies)
  160. Wilwood Aero6 6.52” (1 replies)
  161. 73 Firebird with C5 brakes upgrade to Willwood Areo or FNSL (2 replies)
  162. How can I get smaller brakes w/ATS spindles (1 replies)
  163. Need info on S10 big brake kit (4 replies)
  164. MC recommendations... (11 replies)
  165. Rotor Thickness Factors (3 replies)
  166. Master cylinder bore size (4 replies)
  167. Hydroboost issues....to sensitive (17 replies)
  168. Porsche caliper swap help (0 replies)
  169. Rear Drum versus Rear Disc Conversion Question (2 replies)
  170. Removing the eBrake on an automatic car (7 replies)
  171. 1980 Camaro with C5 brakes (2 replies)
  172. Hydroboost issue (15 replies)
  173. E-Stopp Electric e-brake info wanted (3 replies)
  174. Weird Hydroboost Issue (7 replies)
  175. Hydroboost Bracket (3 replies)
  176. LT Rear brake adjustment (0 replies)
  177. Centering Rear Rotor w/floating calipers (1 replies)
  178. 1st gen camaro hub recommendations. (20 replies)
  179. Wilwood Master with Stock Brake Lines (6 replies)
  180. 1st Gen using 4th, 5th Gen rear brakes? (2 replies)
  181. Caliper Piston Retracting (5 replies)
  182. 96 Z 28 Brake Upgrade (5 replies)
  183. C1 Corvette build, ZL1 Caliper/ C6 spindle fitment ? (6 replies)
  184. Draining master cylinder (5 replies)
  185. Brakes help. (8 replies)
  186. Master cylinder bore sizing. (7 replies)
  187. Chevelle disc brakes (4 replies)
  188. Baer 13" SS4 on my 69 camaro (3 replies)
  189. Hydroboost accumulator issue? (2 replies)
  190. 69 Camaro rear disc 15” rally (0 replies)
  191. Emergency Brake set up for pro touring car (10 replies)
  192. Need Brake Booster Help (1 replies)
  193. Need help bleeding brakes (8 replies)
  194. Wilwood D52-R (2 replies)
  195. Need help bench bleeding master cylinder (2 replies)
  196. Pad Knockback Issue (13 replies)
  197. 1969 Camaro brakes (9 replies)
  198. Baffling brake problem (4 replies)
  199. Wilwood Remote Master Cylinder HELP (4 replies)
  200. New Brake system, any tips (2 replies)
  201. Need help with C6 Spindle Brake options (8 replies)
  202. 65 Galaxie brake guidance (1 replies)
  203. Moving from hydroboost to vacuum booster with c6 z06 brakes (3 replies)
  204. Hydroboost leak HELP (0 replies)
  205. Brakes experts, serious advice needed (4 replies)
  206. 1986 C10 rear disc brake conversion (0 replies)
  207. Anyone have a source for C6 Z06 brakes? (16 replies)
  208. Baer radial mount studs (0 replies)
  209. Hydratech Hydroboost / Baer Remaster - Need Help (0 replies)
  210. Can't find a Hydroboost mounting bracket (7 replies)
  211. Help choosing master cylinder. Camaro -68 Wilwood (3 replies)
  212. Bosch Motorsport ABS (6 replies)
  213. BMW M5 brake squeal (2 replies)
  214. Well number 4 new tool, another Phoenix Injector reverse bleeding tool (1 replies)
  215. Question on properly bracing your firewall for manual brake setup - 69 Camaro (1 replies)
  216. 2014 Mustang GT 5.0 Brembo brakes brake dust. (3 replies)
  217. Needing opinions in choosing brakes. (7 replies)
  218. Lugcentric with 15mm wheel spacers (2 replies)
  219. 1980 F body master cylinder and booster (3 replies)
  220. LS1 rear brakes swap onto Pontiac (6 replies)
  221. What take pads for daily driver half ton pick up? (1 replies)
  222. Hydroboost brake line kit? (11 replies)
  223. Wilwood brake system dragging (6 replies)
  224. Wilwood 4-Wheel Disc Kit Having Trouble Locking Rear Wheels While Truck Is In the Air (4 replies)
  225. manual master size with fbody brakes on chevelle (2 replies)
  226. Brake pedal sticking (3 replies)
  227. Rear Brakes with E -brake - 12 Bolt Options (5 replies)
  228. Brake pedal ergonomics (4 replies)
  229. C6Z06 Brakes with 18" Ridler 650 Wheels (0 replies)
  230. Brake line sizing (1 replies)
  231. Stainless brake lines (3 replies)
  232. M/C size recommendation..... (3 replies)
  233. Decent replacement for GM R-clips? (2 replies)
  234. Hydroboost fittings thread sizes? (4 replies)
  235. Wilwood brake system spongy pedal issue (18 replies)
  236. LT1-style rear caliper leak (2 replies)
  237. LS1 rear disc swap spacer (12 replies)
  238. 69 Camaro/ Lsa swap with hydroboost (5 replies)
  239. 68 nova disk brake options (4 replies)
  240. What is this called and where can I get a new one? (1 replies)
  241. How to Bench Bleed a Master Cylinder - Wilwood Disc Brakes (2 replies)
  242. Master Power....BAER Brakes (6 replies)
  243. Brake lockup issue (8 replies)
  244. Manual vs power brakes? (11 replies)
  245. Brake pedal not returning (3 replies)
  246. which wilwood disc will work on my 67 camaro with 15x7 rally wheels? (5 replies)
  247. Lokar e-brake cable connecting to stock pedal (4 replies)
  248. Can brake pads be shaved down without ruining them? (3 replies)
  249. Hydratech unbox and installation videos :) (1 replies)
  250. E-Stopp mounting location first gen? (14 replies)
