    Results 1 to 3 of 3
      Sep 2011
      manual master size with fbody brakes on chevelle
      looking at getting a wilwood manual master for my 70 chevelle, im running ls1 front brakes and s10 rear disk. would 7/8 or 15/16 be the best choice. im running a 1 inch on the oem front disk and s10 rear at the moment and the brakes are very firm and id like a little more power.
      Feb 2018
      Southern IN
      I run a Baer remaster in 15/16 manual setup with their 6 piston front/4 piston rears per their recommendation and love the pedal feel but I’d call Wilwood as they may have a different recommendation for your specific needs/setup. You may be prepared to answer some questions about about pedal ratio as well.
      Shane
      #theanchorholds
      68 Camaro build thread:
      http://lateral-g.net/forums/showthread.php?t=56387
      15/16th should be good. Plenty of cheap OEM options or the Baer is a really nice part. I use it on my Cougar.
