View Full Version : G-Body Rear Brake Options
ElkySS89
06-24-2025, 07:30 AM
I see a bunch of different rear disk brake kits that all look very similar but some of them are $400 and some of them are $1000. What's the best bang for the buck kit that has good balance with C5 fronts? Or would it be a good choice to just put good shoes and drums on the stock rears?
79 Camaro
06-24-2025, 05:20 PM
I've used C5 front disc's and 1997 Camaro and 2002 Camaro rear discs on a number of swaps.
I prefer the 2002 Camaro since it has the e-brake configured as small drum brake inside the rotor. I use a Wilwood adjustable prop valve.
My go to guy for brake advice Tobin at KORE3>com
Jk918
06-24-2025, 06:49 PM
What rear is in your G body? Ls1 camaro(98-2002) rear brakes are a good option if you can find the parts, C5 rear brakes would be another good choice
ElkySS89
06-25-2025, 02:23 AM
Just a stock 7.5.
Do LS1 rears use the stock parking brake cables?
79 Camaro
06-26-2025, 12:04 PM
On my hot rod projects I use the Lokar e-brake universal cables. They come with a bracket that slips right over the 2002 Camaro e-brake "arm".
