View Full Version : E-Stopp mounting location first gen?
Senek67RS
03-07-2020, 09:58 AM
I am running a full speed tech kit without subframe connectors and trying to figure out some location options for mounting the unit. I thought I had seen someone mount it on the back side of the rear seat in the trunk, but can’t seem to find that thread.
John McIntire
03-07-2020, 10:17 AM
I believe this is the thread you're talking about. I'd like to do the same thing. Start with post #48.
https://www.pro-touring.com/threads/125828-69-Camaro-RS-LSA-TR6060-and-0-Fab-Skills/page2
Senek67RS
03-07-2020, 10:46 AM
Thank you!
John McIntire
03-07-2020, 07:56 PM
No problem, let us all know what you wind up doing!
Senek67RS
03-07-2020, 08:54 PM
will do.
parsonsj
03-08-2020, 06:58 AM
The simplest place to mount the E-Stopp actuator is under the floor, attaching it to the sheetmetal. Look for where the seat brace flange is spot-welded to the floor and you'll find a spot where all 4 corners of the actuator can be mounted through flanges so that it's bolted through two layers of sheet metal. You will need to space the back of the actuator down slightly, and weld in a small floor reinforcement point where the actuator cable mount needs to go.
From there, connect the cable to your parking brake lever using the factory cable guides.
I only run a single actuator to a single brake, and it works great -- it will stall the car if you try to drive away with the brake set.
As I said, that's the simplest way. :)
John McIntire
03-09-2020, 12:25 PM
John,
I was looking to mount the actuator in the trunk near the rear seats. I know that the simplest way would be like you described, but I was concerned about space next to the subframe and between the exhaust. The problem I was having was mounting the actuator perpendicular to the frame and being able to attach both left and right parking brakes and have it pull them both equally.
So on your setup, you're only engaging one wheels parking brake? That would be easy to do while mounting it in the trunk area. I just want to make sure it holds and works as this is a manual car and want to be able to have it run while sitting without me in it.
Thanks!
parsonsj
03-09-2020, 05:52 PM
Hi John,
Yes, just one wheel. Like I said above, if you forget to release it, you'll stall the engine when moving. It most definitely holds just fine that way.
130fe
03-10-2020, 05:44 AM
John, do you happen to have any pics of mounting it where you are talking about? Do you think it will hold the car on a slanted driveway with only one wheel also?
sjaroslo
03-10-2020, 10:17 AM
Here's another alternative. The assumption being that eventually I'll have a false floor in the trunk to cover it up. I think that the shop actually created the mounting bracket incorrectly; as you can see, there is no adjustability in the actual unit, which would have been a good idea, above and beyond what can be achieved with the individual cable adjustments. But it works very well.
173658
173659
TheJDMan
03-10-2020, 12:24 PM
Hey John, I had not even considered only one wheel but that makes a lot of sense. Now I have to rethink how I plan to lay out my park brake.
parsonsj
03-10-2020, 02:26 PM
Here's a pic of what I did.
https://www.pro-touring.com/threads/103144-II-Much-Fabrication-LS9-powered-69-Camaro?p=1140309#post1140309
As far as it holding on a downhill driveway, no problem at all. To a point, you know... it won't hold on a cliff. :)
eville
03-10-2020, 02:30 PM
Other than look is there a reason not to connect both sides? Other than length (routing) the two cables will pull the same distance. Right?
130fe
03-11-2020, 01:34 AM
Thanks for the info John!
Motobrewmaster
03-11-2020, 03:25 AM
I like how clean this is. I am using the stock system and HATE the cable routing across the bottom of the car. Looks like next winters project.
Oh and John that oval exhaust in that picture is SEXY! I would love to learn more about that. Hit me in a pm if you can.
Cheers, Steve
