View Full Version : Baer brakes w/ Baer or Wilwood Master Manual Setup
1daychevelle
05-16-2025, 12:10 PM
I did a search and I'm not finding opinions from real world experience on this topic (differences between the two). I prefer the looks of the Baer Master although performance is more important with this topic, obviously. From what I understand you want a smaller bore size for a manual setup (not sure if this is accurate, looking for advice). That said, Baer offers a 15/16", 1" and 1-1/8". Wilwood offers a smaller 7/8" in addition to the same sizes as Baer. Does the 1/16" smaller bore of the Wilwood perform better or is it not noticeable between the two Master cylinders?
My brake setup:
Front: Baer PRO+ 14" rotor with 6P caliper
Back: Baer 13" rotor with 4P caliper
Cdog
05-17-2025, 06:37 AM
I was at the same X roads before deciding to go with a I booster. I called and spoke to Baer and they recommended a 15/16 piston master cylinder on manual breaks. I would stick to their master cylinder on their brake kit.
JuStBlAzIN
05-17-2025, 07:17 AM
What is your feedback on the ibooster?
Cdog
05-17-2025, 07:49 AM
I don’t have it yet. See my thread in disk brakes
1daychevelle
05-18-2025, 07:42 AM
You mention that you would stick with Baer, Is that because you have experience with a manual configuration and have used both Baer and Wilwood and prefer the Baer MC? If so, what is your reason (i.e. initial bite, pedal effort, modulation, feedback/feel, consistency, etc.) behind choosing the Baer MC?
Cdog
05-18-2025, 09:19 AM
Should you have an issue. the manufacturers will point fingers at each other. Baer engineers for their systems and the like. It's not an absolute but it's a good rule of thumb. What's your time worth fixing problems you didn't know existed? You can't always stick to the same brand but when you can I recommend it.
