CTX-SLPR
03-09-2021, 07:46 PM
Howdy folks,
Can anyone comment on the role rotor thickness has on sizing a brake system? Obviously thicker rotors have more mass to rotate and to suck up heat. Are there any other big driving factors for picking a 32mm thick rotor over a 30mm thick one?
Background:
Since I don't push my nearly two ton Riviera to 8/10th, much less 10/10ths I'm sticking with common rotor sizes I can get at a parts store if something happens on a cross country road trip. I'm going with the Ford/Toyota/Nissan/Hyundai 5x4.5in [5x114.3mm] lug pattern there are lots of choices for 12.5-13in rotors to fill out Mustang type 18in wheels (again a choice more dictated by being able to get Crown Vic front hubs almost anywhere). There is however a clear break between the 12.5-13in and the 14in rotors in terms of readily available thickness, the smaller stuff is 30mm and the larger stuff is 32mm (how's that for mixing units). Calipers are setup for 32mm rotors natively so no worries there about them fitting but going with the thinner rotors also gives me a bit more options for wheels to keep the calipers out of the backside of the spokes.
Background:
