PaulIsFrench
05-20-2024, 04:58 PM
Thank you to anyone that helps :) its much appreciated!
we ordered the hydro-boost blackout kit from POL part#( HB-T6772WB) and the hydro-boost does not seem to be giving any assist. Brake pedal is the same stiffness whether the engine is running or not, I am getting full throw for the master cylinder, all brakes are new, no air in the brake system. Here is a list of the parts we have installed:
Power steering fluid: Royal Purple® Max EZ®
Front Brakes: wilwood 140-11290-R
Rear Brakes: wilwood 140-16711-DR
Power steering pump: GM type II power steering pump
NOTES:
Power Steering lines routed the same as in the diagram of the blackout kit, just has a remote reservoir instead. All brake lines are new, all flex lines are new, all rotors are new, rear axle is new, brakes stop rotors from spinning, just doesn't seem to have any assist from hydroboost. All lines are AN high pressure Lines. Pedal is stiff with the engine on or off. If I hold the brake and start the engine, there is no change in pedal pressure, pedal also returns to top position when the brake is released. Power steering works fine, no issues, brakes have been bled 5+ times, no air in lines. I just need guidance on the hydro-boost, as I am not extremely familiar with them, and I might need a replacement booster... I have removed the return line from the booster to ensure there was no backpressure, but ther is no fluid coming out if the return while braking or while pumping. Let me know what you think.
here is the power steering diagram:
213492
Here are pictures of the lines and routing:
213493213494213495213496213497
NOTES:
213492
