View Full Version : cpp brakes?
Bygblok
01-07-2022, 08:29 AM
Has anyone used the CPP big brake conversion with C5 spindles etc. on a 64-67 Chevelle or another A-body? They advertise it as a zero-offset system(drum brake offset) which is what I need to clear my wheel/tire setup I currently have on the car. They also have a rear brake kit that is set up for a BOP 10/12 bolt that had bolt in axles and I thought about running their product front and rear. Not sure what MC to use yet either since I'm sticking with manual brakes also. Thanks
jetmech442
01-07-2022, 12:47 PM
I had the CPP front/rear disc brake conversion(not the C5 stuff) on my 69 cutlass. The fronts were fine and definitely got me into a disc brake setup. The rears, if they are still using the D154(aka metrics calipers, aka eldorado calipers) with the integrated parking brake, are a complete nightmare. I wasted years trying to get them properly adjusted and could never get a solid pedal. Out of frustration after 6 years I swapped to the wilwood D154 caliper WITHOUT the parking brake, and instant solid pedal and better braking feel overall.
Now, I don't know if the D154 caliper piston area is suitable to run with the C5 piston area, but it's important to make sure they percentages are correct . I would just say stay away form the D154 with integrated parking brake at all cost. Hope this helps.
Bygblok
01-07-2022, 03:27 PM
Thanks for the info and it’s what I’m looking for as far as advise. Their system for the front is the only one I’ve come across that is a zero offset. It’s something I gotta have unless I step down on tire size which isn’t in my plans!
ProTouring442
01-13-2022, 08:25 AM
I've not heard anything really good about CPP, only that they are called "Chinese Poor Products" or "Chinese Poo Poo." YMMV
Charlie_in_OC
01-29-2022, 05:11 PM
Personally I'd look into just swapping 4th gen F body F&R brakes. Might not be "zero offset" considering the thickness of a drum mounting surface VS disc mounting surface, but you're looking at a minute difference.
Tobin @ Kore3 should have the width differences if you really do have the tires pushed to the absolute limit of space.
Smee78
05-01-2022, 02:57 PM
The kit I'm looking at from CPP uses 11" 1979-81 Malibu brake rotors and 1981-92 S10 calipers so I'm not worried about Chinese parts.
sanman
01-29-2025, 12:05 PM
Hi Jett,
Going through the same thing with those rear brakes on a 67 Camaro, fronts are fine. Rears are a PITA to get adjusted/blead. On your Wilwood changeover what was entailed? New Rotors, mounting hardware and such?
Thanks in advance,
Chris Sanford
chris.sanford899atgmaildotcom
