View Full Version : Emergency Brake set up for pro touring car
68 camaro
10-12-2020, 10:06 PM
Anyone set up an emergency brake on a first generation camaro that has disk brakes in the rear? what kit works? i have baer claw brakes on my 68 Camaro both front and back. i need the ebrake to pass inspection. anyone have a lead? forgot to add. i have a ford 9 rear
130fe
10-13-2020, 04:28 AM
Are they newer or older Baer brakes? Post a pic of what they look like.
Sbeck09
10-13-2020, 09:10 AM
I've been looking into the electric parking brakes offered now. I love the idea of not needing to run cables and linkage. Wilwood has a version and I've also seen guys retrofit the Tesla electric parking brake calipers since you can buy a little control box relatively cheap.
Or there is always E-Stopp, but I'm not sure what you would need for rear calipers to make it work for your specific combo.
130fe
10-13-2020, 10:39 AM
You need to figure out which style Baer stuff you have.
The new style- https://baer.com/12-Rear-SS4-Brake-System-with-Park-Brake-4262236.html
Or
The old style- https://shop.speedunlimited.com/p-3600-baer-1967-camarofirebird-11-rear-disc-brakes-kit.aspx
Two different style that require different parts for the PB. What size rotor is it?
Topless69
12-25-2020, 08:50 AM
Also interested in e-brake which I'll be doing soon. Appreciate a quick point in the correct direction to applicable links. Thanks. Jeoffery.
fun2run
12-25-2020, 01:52 PM
https://www.estopp.com/
Running E Stopp Here...works great. Wilwood's new electric brake is nice option but probably not with Baer brakes for differing brands reasons.
https://static1.pt-content.com/images/pt/2020/12/IMG6720-1.jpg (https://postimg.cc/rzQ4hH9c)
https://static1.pt-content.com/images/pt/2020/12/IMG6719-1.jpg (https://postimg.cc/zLCbT2fs)
https://static1.pt-content.com/images/pt/2020/12/0E072AA77A5745DF8A727D9628FCBD8C-1.jpg (https://postimg.cc/zyddHxVK)
https://static1.pt-content.com/images/pt/2020/12/IMG6715-1.jpg (https://postimg.cc/fVm0Tdz8)
Topless69
12-25-2020, 04:51 PM
That is some James Bond s***!!!!:hail: LOL
icemanrd19
12-25-2020, 06:34 PM
What reinforcement did you use for the transmission brackets to the floor? I wonder how much flex there might be
fun2run
12-26-2020, 05:57 AM
Those mounting brackets go thru the floor and the large 1/8 plate gusset then all welded. No flex at all.
Motobrewmaster
12-26-2020, 08:08 AM
Very nice work on your install. You did a great job of incorporating everything and keeping it clean and simple. Well done sir!
MonzaRacer
01-02-2021, 03:54 PM
There is also the S10 rear disc option. Plenty of backing plate setups on ebay. That's what I'll run on my 77Monza most likely.
