    Results 1 to 1 of 1
      May 2008
      Baton Rouge, LA
      Hydratech Hydroboost / Baer Remaster - Need Help
      I tried to start the brake bleeding process today. After working all day to purge the air I found that I have a small leak at the rear of a brand new Baer Remaster MC. Its coming from around where the proportioning valve bolts up. It doesn't appear to be coming from the flange that bolts up to the boost unit. But, its very hard to tell as its a small leak.
      This leads me to believe that the MC has a bad seal and causing it to leak out the rear, but wanted to get everyone's advice before I pull everything out. Is there anything else that could cause one to leak around that area?
