k72nova
10-03-2022, 10:19 AM
BLUF: My front right brake locks up easily while the front left seems to be doing just about nothing, the rears are both working.
I have wildwood Aero6 brakes in the front of my ’72 Nova, I have bled the brakes repeatedly to try and fix this issue and just can’t get my brakes to lock equally or even to have the left lock at all, the car pulls pretty hard to the right when I brake. For context my front right will lock at maybe ¾ braking, it doesn’t take me slamming into them, it happens in a straight line and if I’m turning left or right.
The only thing that I can think of is that the RH side of my car sits roughly ½” lower (measured from the frame to the ground) than the LH side, I’ve made up for this by adding more preload to the RH side to lift the car that extra ½”. Would that change the weight of my car enough to affect my brakes?
My question is if not the preload, what could be causing this? Again I’ve bleed to brakes over and over and am not getting any air through my left side at all, I’ve removed the master cylinder and bench bled it again and then re-bled the brakes, checked for leaks in the line and bulging in the braided line, still nothing.
EDIT: Something to add that I forgot to mention is that I removed the pads on the LH side and cleaned them and the rotor really well, even hit them with a blow torch to see if maybe some oil had made its way onto them and while they were out I pressed the brake pedal to see if the pistons were moving, they seemed to be moving since after two full presses on the brake pedal they were about 1/8"-1/4" further out then they had been.
