View Full Version : Wilwood proportioning valve question
Kmart78
09-01-2026, 07:54 PM
Can anyone suggest a good starting point for a Wilwood proportioning valve? I just finished bleeding the brakes and Wilwood suggested starting out with the knob turned all the way in. This is a 500 hp pro touring Camaro build, but still a street car that won’t see track time. Manual, no booster. Any advice would be appreciated.
dontlifttoshift
09-02-2026, 04:07 AM
All the way in, out half a turn, is where I always start. Usually it works fine right there but that assumes proper parts selection. Sometimes I have to make adjustments after testing due to improper parts selection.
Kmart78
09-02-2026, 03:14 PM
Thank you!
79 Camaro
09-03-2026, 11:37 AM
As said above 1/2 turn out. Then stopping tests to see how the rear brakes react and adjust from there.
