Results 1 to 19 of 19
08-31-2022 #1
Front calipers won't build pressure
68 Cutlass, stock front disc calipers, Ford Explorer rear discs, Wilwood master (1" bore) and adjustable proportioning/combo valve, 11" booster, braided stainless soft lines, new hard lines everywhere except along the frame from front to back. Everything is new over the past year.
This setup, with an old brake booster, was operational. The pedal didn't like to return all the time, so I finally replaced the booster. Unfortunately, I overlooked the pushrod. Being ~.080" longer than my old one, the master was partially engaged. Drove it about two miles before I noticed the brakes holding the car back. Managed to make it back home, but they were smoking. Fixed the booster, went to go back out and the pedal was ridiculously soft. I assumed I boiled the fluid. Turned around 100 ft out of my driveway and it hasn't left since.
I have been entirely incapable of getting a firm pedal. I have a motive pressure bleeder that works great, but I just can't seem to get the air out of the system. I've bench bled the master many times, I've even bench bled it with the combo valve attached. Block off all of the ports and the piston is firm. Put it in the car, clear fluid, no air coming out of all of the bleeders, soft pedal.
Finally bought some plugs and tried all four corners. It is both front calipers. Unfortunately, they were relatively new when I boiled the brakes, and even so, I have since replaced both and still have the same issue. Piston moves fine. I've tried everything I can think of here. Even took them off to and moved them around to dislodge any bubbles that might be hiding in there while bleeding. Nothing. Pedal is hard as a rock when I block off both fronts. Soft as ever if I block off the rears.
Calipers at their core are pretty simple little devices. What the heck am I missing?
