    Results 1 to 13 of 13
      Mar 2013
      Sunny Calif
      LS1 rear disc swap spacer
      Where can I find LS1 rear disc backing plate to axle flange spacer. Swapping onto 10 bolt 68 Camaro. Thanks
      Aug 2005
      Hamilton, NJ
      kore3?
      Scott from NJ.
      Vent Windows Forever! ...
      May 2015
      Island Lake, IL
      Mar 2013
      Sunny Calif
      Quote Originally Posted by F-Body International View Post
      sweet! thx
      El Paso, Texas
      Even cheaper. I just used it on an LS1 brake rear swap on a 68 Camaro. Worked like a champ.
      Alex
      https://www.ebay.com/itm/Gm-10-12-bo...ss!79925!US!-1
      https://www.ebay.com/itm/Gm-10-12-bo...ox!79925!US!-1
      Mar 2013
      Sunny Calif
      Quote Originally Posted by CapSS92 View Post
      Alex
      is one for a single item purchase and the other for a pair thanks
      El Paso, Texas
      Both are for pairs.
      Alex
      Mar 2013
      Sunny Calif
      Both are for pairs.
      Alex
      Gottem on order much appreciate the 411.
      El Paso, Texas
      No prob. Post pics when you're done.
      Mar 2013
      Sunny Calif
      Well im half way there, waiting on parts for now.....
      May 2015
      Island Lake, IL
      Which thickness did you go with?
      I have not verified but make sure you have it shimmed to the correct spacing.
      Mar 2013
      Sunny Calif
      Always my friend, if i am anything its meticulous......
      i believe the spacers are .250" in thickness. Have heard of some cutting out Drum brake backing plate for spacer material as well.
      Mar 2013
      Sunny Calif
      Quote Originally Posted by MAGONSTERZ68 View Post
      update, shims showed up they are .130 thick waiting on pads and rotors before I drop axle and get to measuring up.
