View Full Version : 1 1/8 Master sizing up new piston caliper size
$Mike70Z-28
12-07-2023, 05:11 PM
i have a 1 1/8 master with brake booster 11" I'm looking to up grade my calipers. do i go with the biggest piston calipers or the smallest. they have 3 different size piston calipers
dontlifttoshift
12-11-2023, 06:00 AM
How does the pedal feel now? What size are the existing calipers? What sizes are the new calipers available in? What size are your rear brakes?
$Mike70Z-28
12-12-2023, 01:16 PM
The pedal feels good. im going to 6 piston from 4 the back is 4 piston with 3.00 piston area right now
now front is 4 piston
piston 1.75 x 2 piston area 4.80
new 6 piston
1.62 1.38 1.38 x2 piston area 5.06
new back 4 piston
1.75 1.75 x2 piston area 4.80
dontlifttoshift
12-13-2023, 04:56 AM
4.80 to 5.06 isn't a huge difference and should be fine.
There is no way I would run the 4.80 in the back though. The 3.00 is the perfect rear caliper with the 5.06 front, I wouldn't change the area on that one.
$Mike70Z-28
12-13-2023, 06:09 PM
thanks Donny i will take your advice
$Mike70Z-28
12-13-2023, 06:25 PM
do you recommend the wilwood bp-10 brake pad mostly street use once in a while track
dontlifttoshift
12-14-2023, 04:57 AM
Bp-10s will disappear fast on track but will be fine on the street. I would probably look at 20s for the front and 10s in back for a once a year track thing.
It really depends on how you drive on track and how brake intensive the track is and how big your rotors are as well.
$Mike70Z-28
12-14-2023, 05:59 AM
THANKS "BIG" help
