    Results 1 to 5 of 5
      Jul 2002
      Mesquite, TX
      Lokar e-brake cable connecting to stock pedal
      So I've got the Lokar e-brake cable setup (specifically, the EC-80FU).
      I'm sure they don't intend for it to be hooked to a stock 60s pedal, but that's what they're getting here.
      The problem comes in though - the block the cables connect to is threaded as 5/16 fine; the stock GM e-brake cable is threaded as 5/16 coarse.
      (picture from internet)
      I think if I drill the block out and use two nuts to secure/adjust, I'll get to a point where the wrench won't fit between the cables.
      What's the "proper" way to handle this - weld a fine bolt to <something> and attach that something to the coarse threads? Go ahead and drill it out? Re-tap as coarse?
      Mountain Springs, Texas
      I’ve drilled it out and used two nuts. Box end wrench will fit or a 1/4” drive deep socket.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Jul 2002
      Mesquite, TX
      Being a hack is perfectly acceptable; it's not like I'm the king of precision here.
      Thank you, I'll be doing the same.
      Jun 2018
      SW Florida
      Helicoil it for the coarse thread
      Feb 2013
      South Carolina
      I had done that previously - drilled it out.
