View Full Version : New Brake system, any tips
viperman
09-22-2020, 03:00 PM
Hi Everyone,
Finally putting 4 wheel discs on my 69 Camaro. After a lot of measuring, templating,and contemplating, I decided to do the Baer SS4 kit, front and back with a new manual MC. I had manual, so I went that way again.
I am going to install all new lines, etc., but looking for any advice from someone who has been there and done that. Currently factory discs, and drums. I am expecting big things with this upgrade. CHeers@!
Joe
John McIntire
09-22-2020, 05:06 PM
If you're getting stainless lines, the stainless is a little harder material. When tightening with a line wrench, I found it best to tighten the nut and then back it off, then tighten again. I did that 2-3 times per connection in order to get the flare to seat.
I replaced the entire braking system on my 67, so there was no fluid at all in any of the lines. I first bench bled the master cylinder, then mounted to the booster and hooked up all the lines. I then filled the master cylinder to the top, and then cracked all 4 bleeders and let gravity do its thing. I let it sit overnight like this. The next morning I had fluid at all 4 corners. I then closed all the bleeders and then bled the brakes the traditional way. Made 2 passes around the car and had a nice firm pedal.
This method worked great for me. I didn't need one of those pressure or vacuum tools.
Falcon64
10-01-2020, 05:15 PM
I can confirm that John's approach works a treat.....I personally would not use stainless line tho.
Jim.
