View Full Version : BMW M5 brake squeal
andy007
07-19-2020, 09:01 PM
It won't stop, make it go away! I've tried new pads, two different brands, new discs, help
andrewb70
07-20-2020, 09:28 AM
Various companies make sticky spray stuff that you spray on the back side of the pad, between the pad and pistons. That should do it.
GoodysGotaCuda
07-20-2020, 02:35 PM
Back when I was a BMW tech, one trick we did was to put a chamfer on the top edge of the pads. Not sure how well it worked but it was a TSB fix at one point.
Also make sure you really put some heat in to set the pads. It's pretty hard on performance brakes to putt around and glide to a stop all of the time.
