View Full Version : Need info on S10 big brake kit
BK2LIFE
03-24-2021, 12:04 AM
There are several kits available, and many adapters to mount corvette and other styles of calipers/rotors to these trucks.
I have used the search feature and didn’t find any s10s on this page.
Does anyone have any real world experience with these trucks/chassis and know what works, and what is just spending too much money on?
6 pot 14 inch Wilwoods up front seem to be too much brake for such a small vehicle. Any thoughts?
Thanks for any thoughts
130fe
03-24-2021, 02:37 AM
What year S10? What wheels are you going to run? What is your budget? No magic answer but this might help you.
https://www.pro-touring.com/threads/85773-Budget-85-S-10-Blazer-disc-brake-upgrade
BK2LIFE
03-24-2021, 03:50 AM
What year S10?
84-03 are the same, there is difference in hub in 2000+ but, that’s a non-issue here as both spindles are very easily obtainable.
18+
None.
Lonnies Performance
03-24-2021, 06:18 AM
I'm running C6 Z06 brakes on mine.
Got the kit from Kore3... they make nice kits & have good customer service.
You can also swap to Blazer spindles that use a unit bearing, which may allow more wheel choices since the old style protruding hubs do not always agree with new flat centered wheels.
186213
Here is my build thread.
https://www.pro-touring.com/threads/134524-S10-Xtreme-LS3-T56-Build?highlight=
BK2LIFE
04-30-2022, 06:45 AM
It's been a year now, and I've finally pulled the trigger on the Wilwood Disc Brakes 140-12837, once installed I'll report back on how the system works.
The why for this system, is it has an entire new hub assembly with 1/2-20 studs to match my rear axle. Seems like an easy, no brainer to remove the old, clean the spindles and mount up the new. Quick and simple, low down time.
