View Full Version : Moving from hydroboost to vacuum booster with c6 z06 brakes
tdishon
09-11-2020, 09:10 AM
So I have a 59 Chevy Apache with a c6 drivetrain and z06 brakes. I was building it with the master cylinder under the cab and a hydrobooster. My last project with z06 brakes and a hydrobooster was deathly sensitive to the touch. I suspect I will go with a vacuum booster, but don't have the room under the cab. So my real question is moving the brakes to a firewall mounted setup. Any suggestions on a matched master cylinder and vacuum booster? I have enjoyed a hydrobooder on cars in the past, but with the z06 brakes it is just too sensitive. I almost hate to move the master cylinder into the engine compartment, but I think it will simply perform better.
130fe
09-11-2020, 11:06 AM
What size MC are you using? I thought 1 1/8” MC was good with those brakes and hydro boost. I used to have HB also but switched back to vacuum. My C6 brakes work great with the DSE booster/MC combo.
stab6902
09-11-2020, 01:02 PM
I'm a big fan of vacuum boosted brakes too.
I like the 2009-2013 C6 Corvette OEM Bosch booster/master cylinder. It's the same booster/master that comes in the DSE kits. It'll be a perfect match to your C6 wheel brakes (you will still need an adjustable proportioning valve), and it's tough to beat OEM quality and serviceability. It's a 1" bore. I paid <$100 for my good as new setup from a salvage yard.
Vimes
09-11-2020, 03:39 PM
https://www.hotrod.com/articles/1007sr-abs-electric-power-brake-system/
An alternative, probably pricey, but would allow you to retain the floor mounted braking system.
