Mr Nick
03-07-2022, 11:52 AM
Swapping rear ends from a 1970 Oldsmobile assembly, to a 71-72 BOP 10 bolt.
Using the same C5 rotors (KORE3 kit), I noticed the rotor doesn't fit as snug over the axle register on the new Moser axles. The axle register is 2.755" and the rotor is 2.790. Currie makes register adaptors, but nothing that thin. https://www.currieenterprises.com/parts-department-axle-register-adapters
.035" total clearance doesn't sound like much, but it's enough for the rotor to clearly not rotate perfectly centered. Is this a concern?
