- How to make clean 4 hole cut for Vintage Air hoses?
- NEED HELP with evaporator install
- Painless F5 Peeps
- Where can I buy this style radiator cap?
- Billet AC Dryer Bracket
- How does Restomod Air compare to VA or Classic Auto Air?
- Binary or Trinary?
- Vintage Air Gen IV in a '68 Firebird
- Smoothing out the firewall on a '68 firebird w/ VA Gen IV
- 1967 Camaro Non-AC Heater Core fan Help
- Vintage Air Gen IV blower is surging
- Hoping to fit the Restomod Air Haymaker II in by 69 Firebird
- correct radiator hose 65 gto to 02 LS1
- Best Price for a '66 Chevelle AC system (with lq9/lsx swap)
- Aluminum Radiator and elec fan set up for Chevelle??
- looking for temp/ fan switches for two speed fan
- Testing car after rebuild, A/C pump query
- Vintage Air with F2 procharger
- Vintage air question
- A/C Compressor for LSA on stock subframe
- Holley a/c bracket with a sd7 comp.
- Working on some custom controls for my vintage air
- Vintage Air Explains Binary/Trinary switch in a video!
- OEM style rear window defroster. Does anyone make a nice one?
- Vintage air in a 66-67 GTO.....questions
- Vintage air heater hose routing?
- Control Panel Suggestions for 68 Camaro
- A/C for 1969 Mustang - What brand to buy?
- Vintage Air fan too loud
- Vintage Air Service Port location?
- Need 1st gen Camaro radiator options
- 1986 Elcamino 480HP LS Crate Engine- Looking for A/C Compressor -Which One should I
- Vintage Air Heating Problem- 69 Camaro/LS1
- Brass vs Aluminum
- Vintage Air Gen IV 72 Chevelle - Dissappointed, not blowing air well
- Price for connecting & charging AC system
- 69 Camaro w/ 5th Gen Dash.. Need A/C advice
- *Attn: Vendors/dealers of Vintage Air systems.
- I need Help....!
- Restomod Air Releases New Astro Replacement Ball Vents
- Restomod Air Releases Quantum Vents
- a/c causing error codes po 480
- Restomod Air system for LS1 in second gen F-body
- New Shirts in at Restomod Air
- ac not blowing cold. or even cool.
- Vintage Air / Sanden compressor troubles
- 1967 camaro with LQ4 which vintage air kit??
- Vintage Air Second Gen Firebird Kit Just Released
- Anyone recognize this fitting?
- Truck A/C compressor lifting relief valve
- Heat 101 for this noob.
- Vintage Air ProLine GM Louver Ball
- Vintage air IV - only use for heat?
- Vintage air iv evap core fitting size needed
- gen1 AC low mount bracket
- Restomod Air has just created the world’s first and only Vehicle Climate Control app.
- Anyone with Big Block heater core in 67-69 Camaro.. LOOK HERE!!!
- Vintage air help 67 camaro
- anyone with 67-69 Camaro big block PLEASE LOOK!!
- Keeping vintage air ducts in place without slipping off...any ideas?
- heater core swelled
- Expansion Valve or Orifice Tube?
- Sanden compressor for Vintage Air Sure Fit gen IV
- Eddie Motorsports sd7 manifold
- Blacking out ac hardlines
- AC compressor 90 degree fittings with service ports
- Which style Vintage Air firewall bulkhead?
- Electronic HVAC Conversion for 69 Chevelle?
- 69 Camaro Vent Question
- AC drier position location
- A/C Fittings - Long Pilot vs Short Pilot?
- Vintage air trouble shooting
- ac suction hose will it sweat
- Black Anodized Radiator
- Trunk Mounted A/C System
- AC install, what to do with old wiring
- aeroquip AC charge port cap needed
- Vintage air and LSx conversion
- Coyote swap heater
- Gap between condensor and radiator
- Flexible Bellows Material for A/C Duct
- SD5 or SD7 compressor?
- Vapir 3 Compact Air Conditioning System
- 1st Gen Camaro HVAC Delete Plate
- Vintage AC first gen camaro question....
- Need some help with vintage air heat
- Custom A/C hoses - who's kit?
- AC system install?
- Digital Control for Surefit VA AC
- AC Expert Needed DFW area
- Custom radiator hose suggestions......
- Some Vintage Air advice needed
- Twin or single fans?
- Wanted VA GenII Mini mock up box.
- RestoMod Air, anybody have any experience with them? Opinions?
- Aeroquip socketless fittings/hose
- Thermal Insulation with Sound Dampening
- Electric AC
- 69 Camaro does Vintage Air box take up more room under dash than factory heater box
- Replacing Cable Vintage Air Kit
- Custom aftermarket a/c systems
- How much total freon to add?
- 69 firebird vintage air questions
- Sanden fitment in 1st gen LS swap
- Does anyone is socal (hb) have a ac line crimper
- Custom made A/C hose ??
- Vintage Air Gen IV into 69 Camaro questions
- LS3 water pump inlet/outlet
- Which evaporator?
- Picture of DSE A/C bracket
- Tapping water pump for AN fittings
- Vintage Air Trinary switch wiring, PSI harness
- 69 camaro Vinatge Air center dash vents
- 69 Camaro Vintage air with pro charger
- Water pump hose fitting removal
- VA conversion OEM Levers to electric
- Billet Specialties Bulk Heads for AC & Heat
- 5 rib vs 6 rib serpentine belt
- Fan Noise In My Vintage Air
- What are you guys doing with Astro Ventilation?
- Holley Mid mount serpentine
- School me: what brand gauge set do you recommend?
- AC compressor question
- Vintage Air Gen II in 68 Camaro
- Vintage Air users - share your vent temps? I need mine cooler!
- vintage air gen iv need help
- Smooth vent hoses to boost velocity?
- only works well at high pressure
- Variable flow rate coolant valve
- A/C vents?
- Clear Ceramic Tint - Anyone running it?
- Only 3 bolts for AC compressor/bracket? Is it safe?
- At a loss! Vin air sure fit gen iv giving me fits
- Any early falcon owners use a certain setup for AC?
- Mini compressor vs fullsize? Help me please!
- VintageAir Gen IV Magnum issue
- vintage air / kwik performance belt slip help
- Need help picking a universal unit for my project
- Ac belt slip help !?
- Is my compressor fixed or variable displacement?
- EZ clip ac hoses and fittings
- Vintage Air on a 65 Malibu SS with LT1
- 73 Trans Am LS3 Swap - AirCon options?
- Vintage Air lost my install instructions
- Firewall Bulkhead Fitting
- Blower Motor And Housing Removal - Can I do it without taking out my inner fenders?
- VA/CAA Install Question
- Vintage Air EZ Clip Help
- R134 VA system charging,
- Sanden Compressor Port Position
- Refrigerant Finders...... Real deal?
- Vintage air Binary Switch / GM Pressure Sensor
- AC compressor
- VA Install - 1969 Camaro without Fender Removal?
- 1967-1968 F-body Ball AC Vents
- Aeroquip SS Braided A/C hose and fittings
- LSA Detroit Speed frame A/C
- Vintage air condensor
- 1969 Astro Ventilation Air source
- Eddie Motorsports low profile manifold for Sanden s7b10 compressor
- New Dakota Digital Fan Controller for The Camaro
- Vintage Air AC controls Gen IV
- Where/How to make custom A/C Hard Lines?
- Gauging interest in a customizable vintage air controller
- Ac help for ls3 conversion in 71 camaro with factory ac
- Vintage Air Heat and Defrost only
- Heater Hoses
- 1967 Camaro Vintage air Astro Vents
- Vintage Air Gen IV Surefit 2nd Gen Camaro LS3 6L80e
- Vintage Air Bulkhead
- VA Surefit 67 Camaro
- Pag oil in compressor for startup of new crate motor
- Vintage Air Bluetooth
- A/C help for A 2008 GT 500 engine in a 1967 Mustang
- Vintage air fender hose routing with kick panel speakers
- Fitting for two temp sensors
- So what am I lacking?
- Factory AC Explained
- AC system design - orifice tybe, expansion valve, and HP draw?
- Vintage Air and Bowler Tunnel + Manny More on a 70 Chevelle
- Trinary switch adapted onto a metric A/C port?
- Why are HVAC blower motors located at the beginning of the plenum box?
- Vintage Air Gen IV blower problem
- center dash vent
- Power & Ground Connection for Vintage Air
- Vintage Air controls for Magnum
- How to control current inrush for an HVAC compressor
- Double Pane Side Glass
- New release! Nuk pod a/c controller
- Questions on swapping my VA compressor & re-charging
- Tensioner Vintage Air
- Questions on ordering Vintage Air for 69 Camaro
- A/C Help After 5.3 Swap
- Ac issues
- Question on VA EZ crimp fittings/hose
- VA or Classic Auto Air...what to buy
- Gen V LT4 Air Conditioning Wiring
- Classic Auto Air Reroute
- Vintage Air wait times
- 68 Cutlass - Vintage Air Drivers Side Dash Duct Routing
- ClassicAutoAir inbound delivery
- Vintage air hose routing
- Which VA setup
- DD Gen iv AC controller
- 69 Camaro VA install question- IImuch bulkhead and EZ Clip
- Vintage Air plumbing: Will this work?
- Restomod AC
- Vintage Air colder when sitting still
- Vintage Air mount in 68 Camaro
- Looking for A/C firewall pass-through bulkheak that is NOT a II Much
- Vintage Air Gen V?
- A/c hose length
- F Body LOW MOUNT HOLLEY A/C BRACKET and SWAY BAR CLEARANCE?
- Charging Vintage Air System - Sanden Compressor
- compressor fittings
- Vintage air for 1939 Chevrolet
- BBC coolant problem
- 69 camaro Center AC vent question
- Please check my thought process
- Vehicle Prep for AC Effectiveness
- Variable or Fixed Displacement Compressor
- Best place to buy vintage air
- e-z clip question
- DS Vent 69 Camaro DSE Dash
- Binary A/C switch fan activation
- heater lines
- Need AC help please
- Ac lines sweating terribly
- SD7 adapter not sealing
- 69 AC controls
- Vintage air vs restomod vs classic air
- Vintage Air AC light question
- 71 cutlass LS AC compressor with factory AC system
- Put a PWM on my A/C blower motor
- Vintage AC Smells Like EXhaust
