MAGONSTERZ68
10-11-2015, 06:53 PM
68 camaro LS2 4L60e swap using Holley kit motor mounts, trans mount, mid length headers and FAST pan.
2010 camaro accessory alt bracket and water pump, frame notched and boxed fits good.
Want to run low mount pass side AC and frame is already notched and boxed.
Problem: Holley kit places motor low and using single tensioner mounted from bottom will contact sway bar but found that street and perf had a double tensioner that moved sd5 pump forward to run off of main single belt set up.
had to add a fixed tensioner as factory tensioner is too weak to negate belt slip.
