View Full Version : AC compressor 90 degree fittings with service ports
icemanrd19
02-06-2016, 08:28 PM
I have my vintage air ac compressor on its side. I want to use two 90 degree angle fittings coming off of the compressor. The 90 that vintage air has would have the port facing towards the passanger fender. For the top hose thats fine. The problem is the bottom hose the service port would hit the fender. Does anyone make 90 degree ac fittings that the service port would be facing up?
If you were holding the fitting in your hand with the screw on facing away the service port would be on your right hand side.
1976CamaroGuy
02-12-2016, 05:22 AM
I just had to rotate my ports to get a cruise module beside the fender, I used these to fix my issue. Cost me $17 shipped for both pieces. I ended up using just one fitting.
Maybe this will help you too
https://coldhose.com/10-male-insert-o-ring-by-90-degree-adapter.html
https://coldhose.com/8-male-insert-o-ring-by-90-degree-adapter.html
https://static1.pt-content.com/images/pt/2016/02/2016012420163231_zpsq1h2uqud-1.jpg (http://s1310.photobucket.com/user/1971camaroguy/media/2016-01-24%2016.32.31_zpsq1h2uqud.jpg.html)
icemanrd19
02-12-2016, 08:03 PM
Darn. I just made my lines and these would have been perfect. Ordered anyway thank you
kevin_L
02-12-2016, 08:45 PM
Subscribed, Interested too. Thanks.
