View Full Version : Question on VA EZ crimp fittings/hose
cwmusser
09-11-2021, 01:12 PM
I want to switch out a couple of my hoses to the EZ crimp product line. Summit carries all the fittings but not the hose and it seems to take quite a while to get the hose. Does anyone know if it is necessary to use the EZ crimp hose from VA or can/does any R134 approved hose work just fine? I need #8 and #10. Thank you!
Bad Bowtie
09-11-2021, 01:38 PM
The Vintage Air hose is manufactured by Eaton / Aeroquip. You don't necessarily have to use Vintage Air part numbers to acquire the hose you need.
Not sure if the hose at your local parts store would be compatible with the Aeroquip EZ clip hose fittings and clamps as I think most of those hoses are larger diameter for a compressed collar type installation.
BB
dhutton
09-11-2021, 04:03 PM
You need EZ clip hose. Regular hose won’t work.
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2334524.m570.l1313&_nkw=e-z+clip+hose&_sacat=0&LH_TitleDesc=0&_odkw=ez+clip+hose&_osacat=0
https://www.summitracing.com/search/part-type/air-conditioning-hoses-and-lines?SortBy=BestKeywordMatch&SortOrder=Ascending&keyword=Ez+clip+hose
Don
showdog75
09-12-2021, 03:18 AM
I buy my Eaton aeroquip hose at a local hydraulic hose shop and also a local Thermaking. Thermaking does tractor trailer AC/refrigerant stuff.
cwmusser
09-12-2021, 06:37 PM
Your responses have made it easier to just look for the Eaton product line. The #10 is GH001-10 and # 8 is GH001-8 and so on.
Thanks again!
130fe
09-13-2021, 04:21 AM
191995A friend of mine sent me this. These were the parts he used for his install. Might give someone some help in finding the individual parts.
