    Results 1 to 4 of 4
      Holley a/c bracket with a sd7 comp.
      Hi guys, I have a 67 Camaro with a LS. Iam working on installing the Holley a/c bracket with a sd7 compressor. I don't have the fitting/hoses yet. Iam just worried on how close the compressor fittings are to the inner fender well. Like to see what others have done with the similar set up, pictures would be great. Thanks, Roy
      If anybody wants to just text me a picture, 7074904676
      Walla Walla, WA
      Does this help at all? This is in a '68.
      Mike Kelcy - '68 Camaro with some stuff done to it.
      Thank you for the picture,very clean!, but I have a sd7(peanut) compressor, and the lines come out the side. I should of just went with the compressor you have for more clearance between the inner fenderwell. I've been looking around and I haven't seen actual pictures, and I know it's been done before! Thanks again.
      Mar 2013
      Pittsburgh, PA
      That 508 has both side and rear hose mountings depending on the rear cover, look at their Website
