    Results 1 to 20 of 21
    Thread: Ac issues
      Jul 2012
      eden ga
      Ac issues
      I just put in a ACsystem vac it down no leaks put the pag oil like required then tried to gas it could not get the low side to come up? Anyone have any ideas what wrong. It was 95 here as I was trying to has it.
Size:  258.6 KBName:  7834102D-706A-410E-8C9D-BE9D5D945BD5.jpg
Size:  283.7 KBName:  245A8BAF-9309-42D3-BD3F-AB341763442D.jpg
Size:  231.3 KBName:  301E98E7-1390-493E-9FF2-E80560128BF3.jpg
Size:  256.2 KBName:  0AABBC96-AE70-49A9-AAF5-E301656DE2BE.jpg
Size:  214.2 KBName:  9180BB70-0E0F-4295-8B8D-B1082769989F.jpg
Size:  258.6 KB[ATTACH=CONFIG]190310
      Jul 2012
      eden ga
      I checked to make sure my capaliary tube was clamped in correct spot and it was.
      May 2014
      Louisville, KY
      I’m assuming the evaporator fan was on high. I’ve had to spray water on the condenser before to help bring down pressures where I could get a full charge.
      Mountain Springs, Texas
      Bump up the rpms to 2000 and place the can of refrigerant in water to keep it from getting too cold. Don’t completely submerse it though. Always works for me. Placing a box fan blowing on the evaporator can help too.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Jul 2012
      eden ga
      I had the 30 pound tank in water and a fan blowing so that’s not my issue. I bumped the RPM up to 1800ish and no change. I have .3 mine gas in it that it should have but I back down the gas and does the same thing. I can’t get the low side to come up.
      Jul 2012
      eden ga
      I am being told you can’t run the unit on max air it will freeze up. It’s the way the unit is built now.
      Quote Originally Posted by 5spd540 View Post
      What unit is that?
      Sep 2010
      Beach Park IL
      There is a dial on the capillary tube it may be part of your control panel. Set it so the compressor cycles off at 38-40 degrees based on center vent temperature.
      Donny
      Jul 2012
      eden ga
      My expansion valve is not adjustable. The company I bought it from sucks and they won’t call me back. I have called 4 times and they tell me a tech will call back when they get a chance.
      Sep 2010
      Beach Park IL
      I am not talking about the expansion valve. You mentioned the capillary tube in an earlier post, I assumed that meant you had a thermostat with a tube inserted into the unit.
      Adjusting this controls when the compressor cycles. If it is set too cold, the unit freezes up.
      Donny
      Jul 2012
      eden ga
      Nothing I can do with it will keep it from freezing up other than turn up the temp on the controls in the car.
      Sep 2010
      Beach Park IL
      Right, that's what I am saying. If the manufacturer wasn't a secret, I might be more help.
      This is why Vintage Air uses a thermistor in the case on the GENIV units. That tells the ECU what the temp is, cycling the compressor accordingly so it doesn't freeze up. On the GenII units I have had to hide the thermostat so the customer would quit setting it on kill and freezing the unit.
      Donny
      Jul 2012
      eden ga
      It’s a nostalgic air
      - - - Updated - - -
      Sep 2010
      Beach Park IL
      Yeah, this is the thing I am talking about.
      If you are using aftermarket controls they can be mounted in many different
      locations, arrangements, and distance from the unit. The important step is to
      insert the silver probe on the thermostat into the evaporator coil. This probe will
      be inserted into the evaporator coil. The probe MUST go into the coil at least 1.5
      to 2 inches.
      It does not matter where it enters the fins on the evaporator, it is only important
      that it is inserted. There will be a 1/2” round white sticker with a hole under it to
      designate where the probe should be inserted into the evaporator.
      Turning the temperature up to keep from freezing the unit is exactly how it is supposed to work.
      How much R134 did you get into the system?
      Donny
      Jul 2012
      eden ga
      1.7 pounds. It’s not weird that the low side is so low?
      Sep 2010
      Beach Park IL
      Not to me......It is the suction side. If it wasn't making cold air, I would be alot more concerned. High side is higher than I would prefer but if it is holding there I wouldn't worry about it.
      Donny
      Jul 2012
      eden ga
      I just have never seen a system have so low pressure on the low side.
      Sep 2004
      Vacaville, CA
      We see that regularly with VA. Not to worry. I used to have a Lexus tech service my VA installs and he said a system can’t possibly work with that low a pressure on the low side. But it does!
      Tim
      67 Camaro RS
      64 Nova SS
      Some aftermarket manufacturers intentionally run low suction pressures to address the use of a smaller evap. Refrigerants have a steep boiling point vs pressure curvein thi region, so a few psi suction pressure reduction makes a large change in evaporator cooling. Low suction pressure evaps do run a higher risk of evap freeze-up
      OEM's address this by using larger evaps and higher suction pressures.
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
      Jul 2012
      eden ga
      So my question is how do you make it cool and not freeze up
