View Full Version : SD5 or SD7 compressor?
badazz81z28
07-27-2016, 05:25 PM
Not sure which to go, compact size of the SD7 or the better performing SD508. What are you all using with LS Swaps?
Tim john---
07-28-2016, 01:55 AM
I have the SD 508, reason being is that it can handle higher RPM's than the SD-7. Mine is a Vintage Air installation in a 69 Firebird w/ a stock LS1 GTO engine.
Tim john---
badazz81z28
07-28-2016, 04:15 AM
Tim john---
Is is it mounted high with a conversion bracket? Do you have pictures?
Ehats the the rpm difference?
showdog75
07-28-2016, 04:47 AM
I've got a 63 chevy II wagon so different cars but still check out reply #6. He works for VA and was very helpful to me on my project. https://www.pro-touring.com/threads/119019-Sanden-compressor-for-Vintage-Air-Sure-Fit-gen-IV
badazz81z28
07-28-2016, 05:14 AM
Well good post, but just talked in circles....what are you all using and are you happy?
rocketrod
07-28-2016, 07:04 AM
I'm using an SD7 mounted up top with a Holley a/c bracket. It works great for the intended use, which is mainly daily driver type use. Personally I don't think you can go wrong with either......just try not to overthink it as both have been used with great results.
badazz81z28
08-10-2016, 04:43 AM
Any other inputs? I'm also thinking about size and room for it. How small is the sd7?
dhutton
08-10-2016, 05:24 AM
Use the bigger SD508 if you have room. You won't regret it living in the desert...
Don
Oregon
08-10-2016, 05:27 AM
Here are the dimensions of the 508 and sd7:
http://www.vintageair.com/catalog11/pg88wc.pdf
