View Full Version : F Body LOW MOUNT HOLLEY A/C BRACKET and SWAY BAR CLEARANCE?
MAGONSTERZ68
02-24-2023, 12:16 PM
LOW MOUNT HOLLEY SD7 A/C BRACKET for LS swap.
Has any one installed this mount in notched crossmember 68 Camaro.
Does the A/C idler/Bracket clear the sway bar?
More so a larger aftermarket Detroit Speed Sway bar?
Called Holley, tech response was vague, " I don't see anything noted in system that states sway bar interference in that application"
205830
MAGONSTERZ68
08-19-2024, 02:33 PM
Ended up having Innovatrix Suspensions bend me up a custom sway bar to clear low mount compressor that sits in original LS rear balancer pulley location. Fit like a glove they dropped center section and moved the turned up ends nearest frame bar mounts.
214512214513
