    Results 1 to 8 of 8
      Sep 2016
      LA - Lower Alabama
      VA/CAA Install Question
      When you install an aftermarket AC system in a first gen Camaro, do you generally block off the vents in the kick panels? I’m doing my sound deadened and insulation at the same time, and it seems like it would best to cover the openings with MLV. But on the other hand, I think it would also be nice to be able to open the vents to let in fresh air.
      Dude are you made of leprechauns? Cause that was awesome!
      Jacksonville, FL
Size:  291.5 KBName:  2257671F-C112-463E-9F0A-7BDD8B15F7C3.jpg
Size:  304.6 KBSome guys leave the stock kickpanel in and you still have “fresh” air option. I originally bought a set of screaming performance kick panels but now I am switching to The Shop, LLC ones. I switched to the aftermarket ones because I wanted a better speaker option. Both of those brands I mentioned come with a “cup” that blocks the fresh air inlet.
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Sep 2010
      Beach Park IL
      I keep the drivers side functional when I can.
      Donny
      I put speakers in my kick panels a long time ago and haven't missed the fresh air vents. Even in my daily driver, I always run the A/C with the vents closed (there's no such thing as "fresh air" in Southern California anyway).
      1971 Camaro
      GM HT383, MiniRam EFI, AFR heads
      "8-speed" trans (700R4 + Gear Vendors OD)
      Sep 2016
      LA - Lower Alabama
      Thanks, everyone. I think I’m going to block off the vents. I’m not one to run with the windows down or vents open very often.
      Jun 2010
      Deployed
      The VA system took away my fresh air, I’m going to install non ac vent kick panels
      1970 Camaro/DSE build
      Sep 2016
      LA - Lower Alabama
      Quote Originally Posted by badazz81z28 View Post
      I've never had one of these cars with factory air. Were the kick panels different if the car had AC from the factory?
      Jul 2018
      My VA kit came with fresh air block off plates. I just thought that was part of the deal
