    Results 1 to 15 of 15
      Nov 2016
      Sulphur, La
      Looking for A/C firewall pass-through bulkheak that is NOT a II Much
      I have given up on receiving the II Muck bulkhead that I ordered and paid for over a year ago that was "in stock" when I ordered it...
      So anyway, I am looking for suggestions on other options for a bulkhead to pass the A/C lines through on a 69 camaro. I plan to run the hoses inside the fender with the bulkhead at the far right side of the firewall.
      Sep 2010
      Beach Park IL
      Four rubber grommets.
      Every other bulkhead is exactly that, a bulkhead which means 8 more fittings in a place where your really can't get at when they leak.
      Donny
      Mountain Springs, Texas
      These clean rings are an option but your hose needs to be the correct diameter.
      https://www.yogisinc.com/product_sea...head+push+thru
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Nov 2014
      Byron, Ga
      100% AGREE, grommets is the way to go
      '66 Chevelle BBC/TKO600r, Holley Sniper EFI, Tanks Inc, RideTech Air Ride, Wilwood, Billet Specialties Toploaders 19"/20", Nitto NT555G2, Octane Lighting LED, DIGI-TAILS Front & Rear, Randy's Spoiler
      Quote Originally Posted by dhutton View Post
      Don
      Don,
      How do these work? It's hard to tell from their little pictures.
      Nov 2016
      Sulphur, La
      If you google it you find some better pics. Interesting pieces.
      I appreciate everyone’s input. My dumbass didn’t even think about using grommets. Supposedly my ii much ships today so if so I’ll use it.
      Don,
      Hi Andrew. You drill a hole mount the clean ring with the two threaded parts and then pass the hose through the ring. Sort of a poor man’s iimuch bulkead but four separate pieces..
      Don
      Is there some sort of o-ring inside that seals against the OD of the hose? Or does the hose fit firmly enough to create its own seal?
      The II MUCH Airport is not a bulkhead fitting, it creates a pass through interface without the need for additional fittings. All of those hoses fit through a 2.5” hole in the firewall.
      Yes there is a small o-ring, that’s why you have to be careful with your hose diameter.
      Don
      Sep 2010
      Beach Park IL
      Quote Originally Posted by JohnUlaszek View Post
      Fully aware, I have used the airport in the past. I'm not the one who called it a bulkhead and was clarifying that all the other ones operated differently.
      Donny
      Nov 2016
      Sulphur, La
      I want to update this to share that I have received the II Much bulkhead.
      Negatives from this purchase: It took a very long time to come in, dates I was given did not happen and II Much is a bit hard to get ahold of.
      Positives: The two times that I did get a hold of them they did offer to refund my money if I wanted. Both times I choose to wait for the product. I know in our present world everyone is waiting on other people so they can get their parts out and not everyone is quick to offer a refund. Product seems to be very nice.
      Summary: I will be needing a fuel vent system in the future and will have no concern about buying from II Much, I will order it very early though.
      Good review. I too have had the long wait but they have been responsive. The product is nice. In todays world we need to plan our parts purchases way in advance.
      Feb 2013
      South Carolina
      Never had any trouble with these:
      https://www.vintageair.com/hose-kits...4-Way%20Square
      Quote Originally Posted by JustJohn View Post
      You add 8 more connections when you use that style of bulkhead which is increasing chances of a leak. iimuch part adds no additional connections which is the benefit.
      Don
